Results 1 to 5 of 5
    New question here. cable tension adjuster
    My bike came with an inline tension adjuster that sits in between a KS Lev seat post and the release for the post. It appears that the adjuster was inserted right next to a noodle. May be wrong but I'm guessing that was done to prevent a kink from forming in the cable.
    Was wondering what the process might be to install each of these and if my guess about anti-kinking is correct. Info would be helpful if/when I have to replace the cable.
    Rephrase your question, not sure what you're asking
    Two questions: 1. In general, how does an in-line tensioner get attached to a cable? 2. How does a noodle get attached?
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: cable tension adjuster
    Noodle? KS levs have a curved cable guide where the cable exits the handle bar mounted lever, which is about 3inch long and allows the cable to turn a 90 degree corner. Is this what you're referring to?
    A tension adjuster is usually done with a barrel adjuster at one end of the cable. It gets attached by screwing it into the apparatus (whether a shifter or a dropper post lever or brake lever) and then threading the cable through it when installing. Same with the curved cable guide. My KS lev did not come with a tensioner though. This might be a feature on later runs.
    If you have further questions, pics would help.
    Tensioner
    Does sound like the thing I called a noodle was a cable guide. I do have a KS on an earlier version; no cable guide. The barrel adjuster butts up against it. See in pix.cable tension adjuster-imag0480.jpg
  1. Cable tension help
    By Reflog in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2013, 11:03 AM
  2. Securing the cable casing in the barrel adjuster?
    By BigwheelsRbest in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-11-2012, 01:54 PM
  3. FD Cable Tension Lock (Screw and Nut)
    By jinda in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-27-2012, 06:55 AM
  4. Too much cable tension
    By Gabe3 in forum Beginner's Corner
    Last Post: 06-07-2011, 10:09 PM
  5. Cable tension - am I too anal???
    By timmaayyy in forum General Discussion
    Last Post: 03-09-2011, 02:59 AM
