Results 1 to 16 of 16
    Jan 2015
    cable housing cutting
    Good evening fellow riders. I just finished installing new cable housing on my Specialized crosstrail and an older Hardrock. Anyway, I'm sure there are folks out there like me that are after an affordable pair of cutters. I know we can't always afford the good stuff. Earlier today I bought a pair of Kobalt cable cutting pliers at Lowes for $15. Those things cut super awesome! I highly recommend them as an affordable alternative to the 30 to 40 dollar cutters I've seen. However you cut your cable housing, I would put these cutters close to the top of the list.
    meow meow
    Reputation: b-kul's Avatar
    most bike branded cable cutters are probably just rebranded units anyways...
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I use aluminum shears. On cheap old housing it used to "split" the outer plastic part, but I haven't ran into that problem in a few years. The aluminum shears are more versatile and I use them for all sorts of other things. I'll probably pick up some cable cutters at some point in the future, for a more even cut at least, but the shears have never let me down and I've had them for years.
    El Gato Malo
    Reputation: Wishful Tomcat's Avatar
    I've always used a Dremel with a cutting disk.
    Quote Originally Posted by Wishful Tomcat View Post
    Probably the cleanest, crushproof way to do it. I'm still using my 15 year old Park
    Reputation: PerfectZero's Avatar
    My teeth have always worked well. I have strong gums.
    definite malingerer
    All bike, all the time
    Reputation: BikeIntelligencer's Avatar
    I run used cable thru new housing before cutting it. Keeps it from pinching. But I like the bike specific cutters. Everything else ends up getting dull and not doing the job.
    http://www.amazon.com/gp/offer-listi...&condition=all
    Pedro are good at a good price.
    Once you have these for cables you can use them with the old cable trick for housing.
    Superglue a new cable where you want to make a cut to stop fraying.
    If I were cutting cable a lot, I'd probably have a cable cutter, but as infrequently as I need to cut cable a Dremel works fine for me.
    Reputation: jkirkpatri's Avatar
    Quote Originally Posted by BikeIntelligencer View Post
    Great idea! Thanks!
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    I have a $6 pair from Harbor Freight that work great. Ironically, Shimano T.E.C. says to use a razor blade.
    Jan 2009
    Quote Originally Posted by HitmenOnlyInc View Post
    you're talking about cutting hydraulic brake hoses, right? I think Shimano would know better than to get a braided steel cable or steel housing with a razor blade.
    El Gato Malo
    Quote Originally Posted by mack_turtle View Post
    Yeah, brake hoses. My bad!
    Reputation: mjydrafter's Avatar
    Aug 2014
    The best non-purpose built cutters I have are a simple pair of Channel Lock brand diagonal cutters. They make a nice cut in both cables and housings.
    The big secret is to grind the housings square and flat after you cut it. If you use a Dremel carefully you can cut and square it in one step.
    The few Jag wires I've run across needed the Dremel since the reinforcing runs parallel to the housing.
    Yes! Whenever bicycles are broken, or menaced by International Communism, Bicycle Repair Man is ready!
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by eb1888 View Post
    These have been working great for me for a few years already.
    The more you ride, the easier it gets........
    the easier it gets, the more you ride.
    Viscous circle
  1. Naked Shifter Cable or Full length Cable Housing?
    By Scott Novak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 04:02 AM
  2. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  3. Is the shifter cable/housing the same as my brake cable/housing
    By dstorjoh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 09:18 AM
  4. QBP cable housing $1/ft; Sram Derailleur cable $2/set; free ship over $30
    By bob13bob in forum Where are the Best Deals?
    Last Post: 03-29-2012, 06:51 AM
  5. Cutting cable trick.
    By Gary H in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-06-2011, 02:42 PM
