Results 1 to 6 of 6
    cable clamp for a ks i950 dropper post
    I have a ks i950 dropper post. The cable zip ties to the frame and that is fine. However the cable housing is always coming out of place where the cable attaches to the post. The wires in the housing are starting to get bent so the housing is getting harder and harder to insert into position. This happens because all the slack comes out of the housing as the bars turn and then when I raise the seat, the housing comes out of the insertion point. I was wondering if anyone had a cable clamp solution that would hold the housing in place against the frame to keep a constant length of the housing available for the seat post to go up and down and enough for the bars to turn.
    Looking at the thompson it looks like they have something that holds the cable in place on the bottom part of the dropper housing.
    Reputation: 006_007's Avatar
    My i950 has the cable housing with cable housing end caps, then where the cap goes into the post there is a small set screw that holds it in place. Sounds to me like you do not have it setup properly.
    Reputation: client_9's Avatar
    I agree. Something isn't right.
    He's talking about this set screw.
    Quote Originally Posted by client_9 View Post
    That is exactly how mine is setup!
    Re: cable clamp for a ks i950 dropper post
    I must have an I900 then. Where can I buy the 950 clamp
    Sent from my SAMSUNG-SGH-I747
    Ok I looked at pictures with both. The cables housing is coming out of the black end cap that fits into the lever as the seat goes up the housing doesn't follow smoothly
  1. Dropper Post Cable Routing on Mojo-C
    By cchough in forum Ibis
    Last Post: 05-28-2013, 10:33 PM
  2. Replies: 3
    Last Post: 03-25-2013, 11:50 PM
  3. Dropper Post Cable Rubbing on Covert
    By stunzeed in forum Transition Bikes
    Last Post: 06-22-2012, 10:50 AM
  4. Dropper Post Cable Routing
    By steve86 in forum Ibis
    Last Post: 06-01-2012, 06:14 PM
  5. Replies: 7
    Last Post: 02-03-2012, 09:33 AM
