Results 1 to 52 of 52
    Oct 2013
    New question here. Boring a Tapered headtube bottom flange to taper?
    So my bike looks like it has a tapered headtube - so I went and bought an upgrade fork than has a tapered steerer.
    Taking a closer look at the headtube, there appears to be a flange on the bottom to fit a 44mm headset bottom cap - which I find rather strange.
    I am aware that there are headsets available for 44mm to 1.5" tapered steerer - but I would rather not fit a traditional headset since this will further lift the front of the bike (the upgrade fork is longer already, I wanted to change the geometry a little on purpose)
    So the question is - can I machine out the flange without destroying the frame?
    Here is kinda what the headtube looks like
    The bike is a Scott Spark 29er Team, 2012
    Should the headtube be butted, or is it usually just straight tube?
    Knowing that the resulting ID of the headtube may differ to standard, a custom bottom cup may be required, which I am ok with.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    This is a great idea. You should totally bore out your headtube. Good things will follow.
    I'm a mountain bike guide in southwest Utah
    Reputation: Rock's Avatar
    Probably won't destroy it, but might make it useless.
    No offence intended, I think I understand "what" you are trying to do, but I can't figure out why. Can't you change geometry of the bike without modifying the frame? I would rather modify the fork (internal spacers) or some other removable piece.
    I would imaging that Scott put many hours and many $$$ to design and engineer the frame, but it's your bike, do what you want.
    How can anyone who's been riding as long as I have, be so slow???
    Oct 2013
    Quote Originally Posted by Silentfoe View Post
    Will do it tonight then
    Oct 2013
    Quote Originally Posted by Rock View Post
    So what I am trying to do is remove the flange that has been left in a tapered headtube so that the headtube can actually take a tapered steerer
    Apr 2014
    Are you sure that it won't take a tapered steerer? I thought they came with straight steerers, but would take tapered as well. This article seems to suggest so, but I haven't found definitive specs.
    But in any case, don't go boring out your headtube.
    Edit: Here's the 2012 Spark manual. It's not model specific though and the headset info says it differs by model. It seems very possible though that you have something like a press fit reducer on the bike now to run the straight steerer. I'd ask your shop if you can't tell.
    Oct 2013
    Quote Originally Posted by MarcusBrody View Post
    Thanks for the links!
    Had a look through the manual, like you said there appears to be 2 variations on the headsets. One being tapered, the other 1 1/8 straight. In both cases the headtube looks like its tapered.
    On closer inspection, mine appears to not have a reducer per se, but the headtube itsself has a flange on it that acts as a reducer - the hole at the bottom of the headtube is 44mm (same as the top)
    The headtube appears not be just a tube, but rather a tube with the bottom bent in again to form a reducer. The diagram in my 1st post shows a cross section of the headtube only
    Hope this makes a little more sense!
    Professional Crastinator
    Reputation: Fleas's Avatar
    Quote Originally Posted by Danielmessem View Post
    I am not familiar with that frame, but is there a chance that there is some sort of insert/reducer that has been painted over to make it look like one single piece? Maybe poke a broom handle through your head tube and whack the flange/reducer with a mallet to see if it comes out.
    I would not recommend irreversible changes to your frame. Removing a lot of material would probably greatly weaken it.
    -F
    It's never easier - you just go faster.
    Oct 2013
    Good idea, just tried that out, unfortunately it appears to be part of the headtube - however the bottom section is quite thick, which is good
    Boring a Tapered headtube bottom flange to taper?-magnifier_20140702_190245.jpg
    Attached Thumbnails Attached Thumbnails Boring a Tapered headtube bottom flange to taper?-magnifier_20140702_190636.jpg
    Apr 2005
    I don't think there's ever a time when it's a good idea to modify a head tube. A head tube failure could easily put you in an ambulance.
    In my opinion, if there were no way to make it work without cutting into the frame, I would sell the tapered steer tube fork and buy a straight steer tube fork.
    Safety issues aside, even if you got it to work and it never failed, I bet it would be prone to creak, bind, be out of alignment, etc.
    Little Bear: SC Superlight 29 | Goldilocks' Bear: Evil The Calling | Big Bear: SC Butcher
    Instead of getting random internet answers, maybe try a store that sells scott bikes or bike company itself?
    Oct 2013
    I am in touch with scott, taking up the issue that the bike was advertised as having a tapered headtube while it really has a straight one
    As for posting on the forum, I found a nice thread simular to this which led me to believe that I may get an answer from someone with experiance doing simular things DIY Tapered Headtube Mod Project
    Unless Scott gives you a new frame, you seem hell bent on messing up a perfectly good one.
    Good luck to you Dude, you'll need it.
    Reputation: RajunCajun44's Avatar
    thats why I shop on amazon or rei... I just simply return the tapered fork for a straight one...
    Wouldn't that be the solution ? can you get a refund on your fork ?
    May 2014
    Quote Originally Posted by MtbAZ44 View Post
    Perhaps if he has not modified the fork, the manufacturer would be willing to swap out the CSU for a straight 1.125".
    Mar 2012
    The difference between a Cane Creek 40 external cup lower (to fit a 44 diameter headset and 1.5" steerer) and a zero stack lower is 8mm. If you are worried about raising the front by that much, you could shorten the fork travel by the same amount and keep the same basic geometry. Sounds a lot better than trying to machine your headtube...
    You would need a Cane Creek ZS44|EC44/40, Chris King InSet 7, or equivalent.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    (edited based on new information)
    Fat-tired Roadie
    Nov 2007
    Your pictures are a little confusing, but I think I'm looking at a head tube with a headset installed. Can you post some pics that aren't so zoomed in, so there are some references for scale and orientation?
    What would you even bore it out with? Are you gonna fix your bike frame on a milling machine or something? Even that wouldn't be easy.
    Oct 2013
    Quote Originally Posted by Kanik View Post
    Yes, milling machine with a boring head. Agree that securing it would be tricky, was thinking of taking only the front triangle and securing/aligning it with some sort of jig
    Oct 2013
    Thanks for all the feedback - here is some more info
    Quote Originally Posted by AndrwSwitch View Post
    Thanks for taking the time to give that feedback, hopefully these pics are better:
    Side view, front view
    Front top with headset installed, ID=44mm, OD ~50mm
    Bottom view with internal headset cup installed: id=44mm, OD ~65mm
    Boring a Tapered headtube bottom flange to taper?-20140703_092141%5B1%5D.jpgBoring a Tapered headtube bottom flange to taper?-20140703_092151%5B1%5D.jpgBoring a Tapered headtube bottom flange to taper?-20140703_092213%5B1%5D.jpgBoring a Tapered headtube bottom flange to taper?-20140703_092202%5B1%5D.jpg
    Appreciate all the frank feedback - In no rush to fit the new fork.
    The 44mm to traditional 1.5" cup is the easy solution, and 8mm is probably ok for geometry - can always give it a try.
    Boring the bottom of the headtube would be an additional 'project', something nice to do.
    From what I understand, this frame came in a version with the same headtube already bored out at the factory - not something that I just want to do without getting as much information as possible.
    While I accept the risks, I would rather learn from others than learn by breaking a perfectly good frame.
    May 2014
    It sure does look like you could punch out that insert.
    From Park Tool, the Onepointfive standard has cups that press into a head tube dia of 49.6mm. If your current bore on the bottom there is for 44 (actual 43.9), I don't see why you couldn't bore out 5.7 mm. It doesn't look like it would make the head tube excessively thin, because it looks like the head tube is made to be bored for either 43.9 or 49.6 mm, and in this case the bike build was able to get away with a 1 1/8 fork and semi-integrated headset, so they just bored it for 43.9 and did that.
    I say do it. Hah. Something like this isn't as stupid as some of these people might make it to be, but I'd reckon most of them wouldn't be able to machine it themselves anyway.
    Oct 2013
    From the manual the same headtube comes with either 44mm or 54mm bore - so thanks, thats the confirmation I was looking for.
    Is there anything special about boring a heatube?
    Of course alignment and final measurements will need to be spot on
    Well on doing some more research, it looks like that 49.6 mm is also for an external cup. I think it would raise the stack less than the one for 44 but maybe not much. The fully integrated headsets for 1.5 steerer is 52 or 54 mm dia, which is maybe pushing it on this head tube. You would have to do the measurements and judge for yourself. Really, I say just keep it at 44 and use the headset for that diameter unless you really trust your judgement.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Un-press(punch) out those straight steer tube adapters.....done. Step-away from the boring press.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Oct 2013
    Even with 54mm ID the wall thickness would be just above 5mm, sounds like plenty - will have to verify that somehow
    Oct 2013
    Quote Originally Posted by Zachariah View Post
    Thats isnt an adaptor, its the cup
    bike tester
    Reputation: syl3's Avatar
    Punch out the current headset cup and have a look around to see what's going on there, if the headtube really is one piece or there's an adapter pressed in.
    If you do decide to go ahead with the bore, and you really really want a zero stack headset, you should know that FSA makes a zs49/40 bottom cup. So there's no need to bore all the way to the zs56 standard, going from 44 to 49 seems quite safe to me considering the wall thickness seen in the photos.
    FSA Gravity 2 ZS49/28,6 - ZS49/40 Steuersatz gŁnstig online kaufen - bike-components
    Modifying it makes it worthless...
    That is a lot of work, for that frame. I say sell it and buy something with dedicated tapered headset. Appears the frame has a tapered "reinforcement" outer head tube, which is still probably 80-90% as stiff. Lots of bikes compete with and exceed this Scott model.
    Oct 2013
    Quote Originally Posted by syl3 View Post
    Oh nice find, thanks!
    Oct 2013
    That just wouldnt be as much fun
    Pro Crastinator
    From the manual the same headtube comes with either 44mm or 54mm bore...
    on that note, i redact my previous statement and apologize for going there...
    Fat-tired Roadie
    Nov 2007
    What are the IDs and ODs you're quoting?
    I thought the OD for a 1-1/8" steer tube was 1-1/8". And for tapered, it necks up to 1.5" at the bottom. Which is still about 38 mm, so less than 44 mm. I think you need to pull your headset and see what's going on in there.
    Personally, I'd be disinclined to do this. Fit specs are often very tight-tolerance, so unless you're set up to ream and hone too, and you can get really good concentricity, I see a lot of ways for this to work out poorly. I'd be more inclined to make an adapter or my own bearing arrangement.
    Oct 2013
    The tolerance is tight, but 0.05mm is ok on a mill
    The 44mm I'm refering to is the ID of the headtube lower
    Good try Man. This bird is gonna fly. There's no stopping this kid.
    Are you ever planning on selling this frame after you make chips? Are you going to disclose that you hacked up this frame on your lunch hour at work?
    Like I said at the start of this thread, I understand what you are trying to do, I just don't understand why?
    Oct 2013
    Would not sell the frame, and if I did would fully disclose
    So the idea is to fit a zero stack / internal headset rather than a traditional / cup one
    MTB B'dos
    Reputation: LyNx's Avatar
    OP, the company did not lie, the HT is a tapered capable one, just not an internally capable one, but an external 44 cup will allow the use of a tapered steerer fork, which you seem dead set against. Looking at your pics it does look like the HT is very thick and it's very possible what you say about it coming bored 2 different ways from the factory, still I wouldn't go doing it myself, not with the tolerances and alignment needed or end up having it not line up with the upper cup and not without confirmation from the manufacturers or consulting a reputable frame builder.
    I observed a similar occurrence the other day on a straight steerer Reba fork, it has the crown the size that would fit a 1.5" steerer, so was also wondering if to save cost they only produce one size crown, designed to fit a 1.5" steerer and just machine to suit what steerer is being pressed in. Sure does make it not look so funny if you had a straight HT frame and one of these forks and then bought a frame with tapered HT, but didn't want to buy a new fork.
    Not as fun and might give you fewer options for thr fork down the road, but you might get the height you want with an external lower cup, cutting the steerer tube down and using a stem with a low stack height? I think riders go for these lower height stems when the st is too short, but it might also get you close to where you want to be.
    Low Stack Stems
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Re: Boring a Tapered headtube bottom flange to taper?
    Good call. Adding 8mm under the headtube will slack the head angle out less than .5 degree. Take out one spacer under the stem & call it done.
    No moss...
    Jul 2013
    Just knock out the bottom cup and put in new cup for a tapered steerer. No need to bore the frame. The bottom cup that is currently in your frame is designed to adapt a tapered steering tube to a straight steerer. You just need a Cane Creek ZS56 lower headset and crown race.
    MTB B'dos
    No, that is not what he needs, if he got a ZS56 (ZS stands for zero stack) he would need a HT designed for a fully internal cup to run a 1.5" steerer, which this isn't, what he needs is the EC44 lower cup or the EC49 depends on how it's currently bored.
    Quote Originally Posted by JB51 View Post
    Rock and/or Roll
    Reputation: turbogrover's Avatar
    Dec 2005
    If you have the ability and experience to machine the headtube, you should be able to best answer this by yourself taking a few simple measurements. If you can't make this call by yourself, then you shouldn't be attempting it.
    I modified a carbon road frame from an english threaded bottom bracket, to PF30 on a milling machine, and it works perfectly fine. No different than a factory designed frame. It didn't require multiple internet opinions.
    It's either possible or it isn't. A dial caliper doesn't lie.
    Oct 2013
    Quote Originally Posted by turbogrover View Post
    Correct you are!
    Posted this hoping that someone else had done something simular, and now I have the answer.
    Also wanted to find out if there are considerations or assumptions which I was forgetting, which there were none, although I will certainly be taking more time for this operarion on the mill.
    Will order a 54mm zs bottom cup today, and bore sometime next week - I will post the results here, accepting that there are risks, and treating this as an experimental hack
    Oct 2013
    Scott tapered head tubes take 54mm not 56mm bottom ZS cups
    MTB B'dos
    Do they actually use a cup, or do they do the drop in Campy style headset? Can't think I'd want balls any smaller than in a normal headset and with a cupped 54mm you'd have to reduce ball size for it to work unless it is a drop in one. Have had ZERO luck with these new Campy style drop in headsets, just don't seem to have good enough seals or maybe it's SpecialED using inferior ones, but have had 5 go on them and 3 Giants with ZS tapered lowers.
    Oct 2013
    They use a cup, just a slightly different size, hope sell both sizes of bottom cup
    I keep expecting to check this thread and see pictures of the frame on a mill followed by a picture of it all assembled with the new tapered fork, but so far all I see is a lot of talk... I say do it and post pictures or let the thread die.
    Oct 2013
    Quote Originally Posted by BobbyWilliams View Post
    Will do it and post pics as soon as its all setup - hopefully this week, but thats dependent on the boring bars arriving
    Now you have to feed the beast, lol....
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    I would not be so concerned that the BB shell fails....it usually does not lead to the same kind of catastrophic failures that a headtube can cause.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
  1. can i fit a tapered fork into my headtube?
    By Johan Brun in forum Downhill - Freeride
    Last Post: 02-23-2014, 10:02 AM
  2. Explain tapered headtube please...
    By GtownViking in forum General Discussion
    Last Post: 08-03-2012, 01:17 PM
  3. What year did the RIP 9 go to tapered headtube?
    By Mike E. in forum Niner Bikes
    Last Post: 10-04-2011, 09:32 PM
  4. Chameleon with a tapered headtube?
    By Just J in forum Santa Cruz
    Last Post: 09-21-2011, 11:54 AM
  5. Replies: 10
    Last Post: 03-16-2011, 12:27 PM
