Boring a Tapered headtube bottom flange to taper?
5K views 51 replies 22 participants last post by  mtnbikej
#1 ·
So my bike looks like it has a tapered headtube - so I went and bought an upgrade fork than has a tapered steerer.
Taking a closer look at the headtube, there appears to be a flange on the bottom to fit a 44mm headset bottom cap - which I find rather strange.
I am aware that there are headsets available for 44mm to 1.5" tapered steerer - but I would rather not fit a traditional headset since this will further lift the front of the bike (the upgrade fork is longer already, I wanted to change the geometry a little on purpose)
So the question is - can I machine out the flange without destroying the frame?
Here is kinda what the headtube looks like
Line Parallel
The bike is a Scott Spark 29er Team, 2012
Should the headtube be butted, or is it usually just straight tube?
Knowing that the resulting ID of the headtube may differ to standard, a custom bottom cup may be required, which I am ok with.
#42 ·
Just knock out the bottom cup and put in new cup for a tapered steerer. No need to bore the frame. The bottom cup that is currently in your frame is designed to adapt a tapered steering tube to a straight steerer. You just need a Cane Creek ZS56 lower headset and crown race.
#43 ·
No, that is not what he needs, if he got a ZS56 (ZS stands for zero stack) he would need a HT designed for a fully internal cup to run a 1.5" steerer, which this isn't, what he needs is the EC44 lower cup or the EC49 depends on how it's currently bored.
#44 ·
If you have the ability and experience to machine the headtube, you should be able to best answer this by yourself taking a few simple measurements. If you can't make this call by yourself, then you shouldn't be attempting it.
I modified a carbon road frame from an english threaded bottom bracket, to PF30 on a milling machine, and it works perfectly fine. No different than a factory designed frame. It didn't require multiple internet opinions.
It's either possible or it isn't. A dial caliper doesn't lie. :)
#45 ·
Correct you are!
Posted this hoping that someone else had done something simular, and now I have the answer.
Also wanted to find out if there are considerations or assumptions which I was forgetting, which there were none, although I will certainly be taking more time for this operarion on the mill.
Will order a 54mm zs bottom cup today, and bore sometime next week - I will post the results here, accepting that there are risks, and treating this as an experimental hack
