Results 1 to 19 of 19
    Black stainless steel cage bolts w/washers. Where to buy?
    Who sells black water bottle cage bolts in BLACK w/washers made from stainless steel. Donít need light, donít want aluminum, donít like look of bright stainless so looking for black but in stainless steel that has been coated or finished in black.
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    I use eBay for this sort of thing, there are so many suppliers. You may need to include the thread size and length to find suitable bolts as you don't need bike specific bolts.
    Any hardware store will have black hex headed bolts. They're m5x0.8 sized.
    My local ace hardware has a surprisingly large selection. I bought some for brakes recently. Home Depot is alright too.
    Got a sharpie?
    Reputation: bamwa's Avatar
    +1 for sharpie
    Keep trying to do the awesomest thing you've ever done.
    Contains no juice.
    Nov 2003
    Quote Originally Posted by bamwa View Post
    +1 for sharpie
    Or a rattle can.
    What's the difference between red and green?
    Apparently nothing if youíre on a bike.
    +1 rattle can. I paint mine red.
    Reputation: nauc's Avatar
    i painted some L brackets and screws with this. turned out great
    Reputation: Flamingtaco's Avatar
    Mar 2012
    Quote Originally Posted by One Pivot View Post
    Those are titanium oxide coated carbon steel. Don't get them wet, they rust after a bit. Never mind, they also rust if you don't get them wet.
    Stainless bolts can be anodized, but most have a DLC coating as it's cheaper. It's a good finish, no worries there. Pro-bolt carries stainless in a few colors, but shipping always bumped the price close to titanium bolts from Toronto Cycles, so I've got about $40 in Ti bolts on each of my bikes.
    Not a weight weenie, just hate rusting bolts.
    I will suffer no butt-hurt fools!
    Exactly, why I was preferably looking for stainless steel coated bolts. Iím in S. Florida everything rusts!
    Dec 2017
    Here are some: M5 A2 Stainless Steel Socket Cap Head Machine Screw in GWR Colourfast
    Shipping to North America is not cheap though.
    One ring to mash them all
    Mar 2015
    Quote Originally Posted by Flamingtaco View Post
    I saw those black Ti bolts on Toronto Cycles yesterday. Apparently you can't anodize Ti black using the same simple technique as for other colors. So disappoint.
    Į\(į_o)/Į
    Sep 2013
    Try McMaster Carr, look up part number 97763A819
    Black Oxide 18-8 Stainless Steel
    Winner! Thank you.
    I will need about 20 but go bit longer and get the 12mm length and matching washers
    Sep 2013
    McMaster Carr is a great resource with a well done website.
    Mar 2015
    Yep, that's a good find. I checked Grainger and didn't see them, but forgot about McMaster Carr.
    Į\(į_o)/Į
    Reputation: LarryFahn's Avatar
    Quote Originally Posted by the one ring View Post
    Or Fastenal
    Hubbard Bike Club
    Albany County Fasteners has black oxide coated stainless steel bolts. You would need M5 size.
    EXODUX Jeff
    Hey yall be careful. Prob ok w ss bolts......but......ss nuts & bolts can gaul. Meaning they can seize then break in the nut. I've seen it on some railings I built. They make a reverse threadlock spray for ss hardware. But a ss bolt into a different metal thread should be ok. Well not sure about aluminum/ss interaction, or what type of metal inserts in carbon frames are made of.
  1. Replies: 6
    Last Post: 11-20-2017, 03:21 PM
  2. Chainring Bolts - Stainless vs Aluminum, / Locktite vs Lube
    By Scott Novak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-11-2013, 01:09 AM
  3. Stainless, Stainless, Stainles....
    By Mark42 in forum Mongoose-Schwinn
    Last Post: 08-08-2012, 12:46 AM
  4. Replies: 7
    Last Post: 10-22-2011, 04:52 PM
  5. 6.6 SS - Link bolts and washers
    By hafnz in forum Intense
    Last Post: 03-05-2011, 08:34 PM
Members who have read this thread: 75
