Trying to get some ideas of how to store my DH and AM bikes from the ceiling. I don't wanna store them upside down and I cannot use the a bike lift. Anyone have ideas on their personal setups. If you have pics please post.
And when you say 'bike lift' do you mean pulleys and rope?
Obviously you can attach some sort of hardware from the ceiling right?
Do you have exposed joists?
Just trying to get an idea of the surface and height you are working with here.
I have a 9' drywalled ceiling. I know where the joist are. It would be in front of a 3rd bay just beyond the end of the door when it's open. The other end has shelving. No where to tie the rope front or back.
I don't wanna hang it upside down because of it may having an effect on the brakes.
I use to hang my Yeti on the wall and if it was up there for a few weeks the brakes would develop air in the lines.
Hang em' from the seat. Here's what I did in the garage. It wasn't built with aesthetics in mind but it works great. 1/2" pre-threaded pipe, a couple of elbows and flanges, and a few screws. Less than $25.
Attach the rack to a surface mounted a backer board spanning the joists where you want to install.
EDIT: I see a few like minded folks. :-)
"That's the smell of fitness."
Foster Farms MTB Chickens
I'd say use a lift, but have a hook on the end of the line, then with a pole/broomhandle hang the end of the line on the bike somewhere so the rest of the cord isn't hanging down in your way.
The bar idea above looks doable too.
I used to hang my kayaks on hooks high up in my shop ceiling space. I had hooks suspended from the I-beams, and a short double hook thing I made that would hook onto the loops of my kayaks and on to the hooks from the beam.
The double hook thing was emt and I had a pole that fit inside.
I'd put the pole in the double hook pipe, hook it to one kayak end and lift it up to the ceiling hook. The repeat with the other end.
Just an idea, though I'm not sure I'd do that exact same thing with a bike.
As far as the brakes go... I contacted Magura, I think, and they said hanging upside down was not an issue as long as the brakes were properly bled... meaning... no air in the lines to start with.
I posted the email a while back but I can post it again if you're interested. Just fyi.
I love this idea except my Yeti has a Reverb and I wouldn't want the 'pulling' on it all the time.
