    Bianchi Kuma 5500 (2011) vs. Trek 6000 (2012)
    Hi friends!
    Which bike should i go for in your opinion? Both are at same price...
    Frame:Bianchi KUMA Alu 2011
    Fork:SF-11-XCR RL
    Headset:FSA NO.10
    Shifters:Shimano DEORE
    Rear Derailleur:Shimano SLX、 9sp
    Front Derailleur:Shimano DEORE
    Crankset:FSA DynaDrive、 44/32/22T
    Chain:KMC X9
    Sprocket:Shimano DEORE CD-HG30-9、 11-32T、 9sp
    Brakes:Shimano DISK BRAKE BR-M445、 center-lock SM-RT53 160mm rotors、 white
    Brake Lever:Included
    Rear Hub:Shimano FH-RM65
    Front Hub:Shimano HB-RM65
    Rims:Mach1 MX Disc、 White/Red Collection、 Front Red/rear White、 32H
    Tire:Python Original WB、 26x2.00
    Stem:Spectra ST58A、 3D torged alloy、 6゜
    Handlebar:Spectra MTB406A、 double butted alu、 riser、 620mm、 white
    Grips:Progrip Art.953、 black/white
    Seatpost:Spectra SP-222、 31.6mm、 white
    Saddle:Bianchi FM5307、 steel rail、 white
    Pedals:Feimin FP-906 +toe-clip
    Trek 6000 (2012)
    Frame:Alpha Gold Aluminum w/semi-integrated head tube, formed down tube w/integrated gusset, formed top tube, monostay seatstay, forged dropouts w/rack & fender mounts, replaceable derailleur hanger
    Fork:SR Suntour XCR-RL w/coil spring, preload, remote lockout, 100mm travel
    Headset:1-1/8" threadless, semi-integrated, semi-cartridge bearings
    Shifters:Shimano Deore M591, 10 speed
    Rear Derailleur:Shimano Deore XT M780 Shadow
    Front Derailleur:Shimano Deore
    Crankset:Shimano M552, 42/32/24
    Chain: n/a
    Sprocket:Shimano HG62-10 11-36, 10 speed
    Brakes:Shimano M446 hydraulic disc brakes
    Brake Lever: n/a
    Rear Hub:Shimano M435 alloy hubs
    Front Hub:Shimano M435 alloy hubs
    Rims:Bontrager AT-850 disc 32-hole rims
    Tire:Bontrager XR1, wire bead, 26x2.2"
    Stem:Bontrager Race Lite, 31.8mm
    Handlebar:Bontrager Low Riser OS, 31.8mm, 15mm rise, 9 degree sweep
    Grips:Bontrager Race Lite
    Seatpost:Bontrager SSR, 31.6mm, 20mm offset
    Saddle:Bontrager Evoke 1
    Pedals:Wellgo alloy platform
    Heart says Bianchi, cos its so damn cool. I'd park it outside the cafe and just look at it!
    Head says Trek cos of the components; 10sp drivetrain with XT shadow tech. From the fork to the pedals you can't go wrong with their buying power.
    From what little I know I would go with the Trek spec-wise. However, have you tried them out?
    May 2012
    Bianchi is very cool...
