Results 1 to 8 of 8
    Reputation: vicAMR's Avatar
    Jul 2014
    which is the best 29er tire for tubeless?
    Thinking on going tubeless for the first time but i dont know which 29er tires are the best for tubeless can you help me out? thanks
    1. MTBbikerX
    2. LOVECYCLING!!! vicAMR!!
    3. Cross CountryMTB!! yeah!!
    BM and PQ Trail Rep
    Reputation: bankerboy's Avatar
    Won't say for traction as that is a personal choice. The bigger issue is getting it to set. Typically a UST tire is easier to set and less likely to leak.
    The world does not revolve around you but your actions impact us all!
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Make a pot of coffee, do a search and get ready to read a whole lot of stuff. Lots of good info here on tubeless tires. I've had great success with Specialized tires thus far.
    Let's make like a Bike and get the Huck outta here...
    Maxxis is the most trouble free tires I've used in Tubeless.
    I highly recommend you get an adapter so you can load the concoction threw the stem rather then dumping straight into the tire. The latter can get messy
    Reputation: Ronnie's Avatar
    Most tyre brands and models are available in either Tubeless Ready or UST versions. It's up to you to decide what tyre you want to use, then get a tubeless version.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Reputation: shiggy's Avatar
    Dec 1998
    Re: which is the best 29er tire for tubeless?
    Quote Originally Posted by vicAMR View Post
    Bontrager TLR or Geax TnT tires on Bonty Duster TLR rims have been the easiest and most reliable for me. Usually with Geax Pit Stop or Slime Pro sealant.
    Tubeless tires mounted on tubeless rims, designed to work together as a system.
    mtbtires.com
    Bandit 29 FTW!!!
    Quote Originally Posted by Bird View Post
    No adapter needed if you have the Stans stems and their 2oz bottle. Stans stems have a removable core. Then use the cone shaped dispenser to squeeze it down into the tube.
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    I have had good luck with Specialized 2bliss, very good luck with Kenda products in their UST and SCT versions. Tires I have had trouble with are Continental both with seating and holding air once seated. It seems they lose air much quicker than other brands.
  1. Best Tubeless Tire for a 29er
    By HouseNotes in forum 29er Components
    Last Post: 09-13-2014, 08:32 AM
  2. Anyone tried to run a WTB Prowler SL 29er tire tubeless?
    By sinac84 in forum Wheels and Tires
    Last Post: 04-24-2014, 08:01 AM
  3. Tubeless 29er tire recommendations
    By eugenemtbing in forum Wheels and Tires
    Last Post: 10-06-2013, 06:15 PM
  4. What's the best Tubeless Tire for a 29er?
    By HouseNotes in forum Great Plains - OK, KS, NE, SD, ND
    Last Post: 10-21-2012, 07:17 AM
  5. Tubeless 29er rim and tire suggestions
    By jahguideini in forum 29er Bikes
    Last Post: 01-23-2011, 10:09 AM
