Results 1 to 23 of 23
    Alternative uses for a bent rim?
    So, I just put a sweet little S-curve into the front wheel of my brand new bike on it's fourth time out. The rim is still pretty clean and new looking aside from the new geometry, and I was wondering how I might put it to use in the garage or maybe even the house, as wall art or something. Any ideas?
    The only thing that comes to mind is maybe as a ceiling mounted pot rack or tool rack...
    I like bikes.
    Reputation: Dirtydogg's Avatar
    Stick it in the closet until something comes to mind.
    I use odd stuff like that in my mulch gardens. i.e. plant a vine next to it with it 1/3 of the rim buried.
    Karakoram...ZS44, X-Fusion, Freq i23, Tioga's, Shadow & XT,Shim Hydro 180/160, MG-1 pedals & more.
    mbtr member
    Reputation: scottzg's Avatar
    Got a cat? Practice being a lion tamer.
    Got a bin of old bike parts? Hang them from the spoke holes with some fishing line and make a giant mobile.
    Got some dish soap? Make huuuuge soap bubbles.
    Got some string? Make a dream catcher.
    Got a tarp? Make a solar shower privacy tube.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Reputation: Hang 21's Avatar
    Put some LED lights on it, throw it up in the air, and report a UFO sighting.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Even a s-bend wheel rim can still be trued back to spec. It takes time, by a skilled and experienced wheel builder...but it can be done. Only the Taco is irreversible....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    mbtr member
    Quote Originally Posted by Zachariah View Post
    As a moderately skilled wheel builder... I'd much rather start with a rim that doesn't start out with funky spoke tensions to begin with. A somewhat exotic rim is what, 100$? I'd almost always rather start out with a fresh rim for my own build- peace of mind and easier work is worth the expense.
    A housecat that will leap through flames, though.... invaluable. A thousand household uses.
    Mikhail Kalashnikov
    That guy
    I once cut up an old rim into many pieces, leaving one spoke hole in each piece, and made key chains that I sold for $5 to help pay for a new rim. Just sayin'....
    Reputation: donutnational's Avatar
    Jan 2013
    Use it to build for a wreath when the holidays come a round, they look good.
    EMBA Member
    Reputation: Ladmo's Avatar
    Jan 2013
    cock ring?
    Reputation: KevinGT's Avatar
    Dec 2012
    Quote Originally Posted by freakybro View Post
    cock ring?
    Winner
    Trued back to perfectly straight, yes absolutely. Evenly tension, not even close. Without even spoke tension the wheel will be weak.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by KevinGT View Post
    Winner
    Yeah if you swing with leather clad underwear.
    Jan 2009
    This works best with Mavic Open Pro rims, but here's my re-purposed rim:
    I used mine moments after taking those photos and I am now enjoying this fine beverage.
    depending on how bad the bend is, you can often "bend it back" and get some more life out of the rim without needing wacky spoke tensions. it depends on how badly you want to fix something rather than replacing it.
    Reputation: Burt4x4's Avatar
    Feb 2013
    Garage Art for now:
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    Reputation: dbhammercycle's Avatar
    My wife is using a couple 20" wheels for some sort of interactive spinning pictorial wall of sorts. There are all sorts of crafty projects to do with various bike parts. Perhaps a lazy susan?
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Aug 2013
    I'm not a wheel builder; but I'm going to assume that if a wheel was bent enough to allow a quarter of the spokes to lose tension, that it lost much of it original specification fatigue resistance. I would only use the aluminum in the rim if there was an ability to re-extrude the aluminum rim.
    Goodbye '95 ZJ. Just so you know, transfering box of left behind womens panties to next truck. Thank you ZJ!
    Dec 2010
    Make a couple coat hangers out of the rim and a few spokes
    Velocity sells them, too
    Seen the you tube fix of a TAco'd wheel three smacks and it pops back straight...permanent
    Ive done the same by jumping on it....not permanent but will get you out..
    Quote Originally Posted by Burt4x4 View Post
    Garage Art for now:
    yup the sharp bend at 3:00 makes that one a goner...
    if the curve is gently all the way around it is fixable.
    Feb 2013
    OH yeah it's a gonner. It split at the seam exposing the "pin" used for holding it togeather. On the valve end there are little dimples next to the valve hole = Toast (cheep stock wheel anyway)
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Trying to properly tension a bent rim is a pain in the but. You'll have slack spokes coming off one side and tensions approaching nipple failure on the other. These are the wheels that are more prone to TACO due to spoke inbalance.
    When the rims get into this state, the next "event" spells replacement. It's less work just to get a new rim and rebuild.
    if you ever go to races, a rim and handle bar make great noise makers
  1. Tubeless alternative?
    By Technician in forum Wheels and Tires
    Last Post: 10-20-2013, 09:21 AM
  2. Alternative/Other options to a Van D WTF
    By ozbikebuddy in forum 29er Bikes
    Last Post: 12-29-2011, 05:40 PM
  3. Looking For An Alternative
    By Stylishxone767 in forum Beginner's Corner
    Last Post: 07-12-2011, 08:16 AM
  4. 5.10 alternative?
    By freeriderB in forum Downhill - Freeride
    Last Post: 05-29-2011, 02:46 PM
