Results 1 to 13 of 13
    Matty-B
    Reputation: Mattyboughton's Avatar
    Jan 2013
    Adjusting Sram Type 2 clutch
    After several months of riding my Sram XX1, the roller beraing clutch on it seemed to be dying and i could here more chain slap going on. Here is how you adjust the clutch to tighten or loosen it.
    1. Take off the plastic cap on the outside of where the bearing is housed in the derailleur.
    2. you can now use an 8mm allen wrench to adjust the preload on the bearing 1/4 to 1/2 a turn
    Reputation: 006_007's Avatar
    What happens if you adjust the bearing more then 1/2 a turn? or less then 1/4 turn? Did it make a difference to the problems you were having? Do the changes stick?
    Matty-B
    Jan 2013
    A 1/4 to 1/2 turn was all the adjusting my derailleur needed. Any more and it felt like the clutch was way too tight. A couple days of riding later and all is still good with the clutch
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Not if it's an X9 type 2. There's T55 torx to get past.
    Matty-B
    Jan 2013
    An 8mm wrench fits that t55
    I can't get the plastic cap off for some reason. Can you post a pic of yours off so I can see how it's setup?
    Reputation: smithcreek's Avatar
    Nov 2012
    Quote Originally Posted by ChrisP125 View Post
    It's not made to come off easy, you have to dig it out with something pointy. I used a utility knife blade.
    This did not work for me.
    My X9 got to the point it would hardly break loose at all.
    I losened the center bolt but 3-4 full motion swings and it self tightens by design.
    Sram is aware of the issue and warrantied me up to X0.
    Feb 2014
    Is there a way to replace the bearings in there with some better one's, mine doesn't have 100 miles on and gets stuck on the top gear all the time.
    Just did this on my crosser with x7 and my mtb with x9. Both had T55 bolts but only needed a 1/4 turn to tighten up the rollerbearing. Thanks for posting this.
    thank you that worked really well today - did like 1.5 turn I think on X9 type2 RD. after 1 year I started dropping the chain frequently (should have looked before as my chain slap got worse over time). Today was fairly quiet - might need bit more to bring it back to new (front NW is likely wearing off too).
    Funny thing I asked a SRAM tech guy at Super Enduro last year and said it wasn't adjustable. Lie!
    Nov 2013
    I need some input. I have a brand new bike, came with a 3x10. I put on a 36 t middle ring, dropped the big ring for a bash and swapped out the x7 for a x7 type 2. Problem is, when I'm in the big ring up front and big ring in the back and then shift down the lower pulley on the RD gets stuck forward of the upper pulley creating a ton of chain slack. Results in dropped chain and shifting issues. I noticed while riding yesterday if I get off the bike and push the lower pulley back the RD snaps back into position. Is this a faulty RD, needs clutch adjustment, or am I missing something?
    2016 Ridley X Trail
    2013 Mount Vision XM6
    2007 Giant OCR2
    Nov 2013
    Worth noting, the type 2 is a medium cage which if I did my homework should work.
    2016 Ridley X Trail
    2007 Giant OCR2
  1. Wear rate on your Clutch type or Type 2's jockey wheels
    By jasonwfreak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2013, 11:17 AM
  2. Has anyone tried running XX1 crankset with non-clutch type derailleur WITHOUT GUIDE
    By Ben_Im in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2013, 01:51 PM
  3. Rotor ring with Sram clutch, XX1 or type 2 rear derailleur?
    By artnshel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2013, 07:22 AM
  4. New SRAM X.0 Rear Derailer w/ Clutch
    By torque29er in forum SRAM
    Last Post: 07-18-2012, 11:31 AM
  5. New SRAM X.0 Rear Derailer w/ Clutch
    By torque29er in forum 29er Components
    Last Post: 04-16-2012, 04:54 AM
