Results 1 to 7 of 7
    Jul 2013
    650b wheel on a 29er fork?
    hi, I was wondering if a 650b wheel would fit on a 29er fork. the reason I would do this is because ther is a better range of 29er forks than there are 650b forks. I was particularly looking at the Rockshox XC28 Magtk. I know this has been covered in other forums but not clearly enough. and would a 650b wheel fit on a 26" wheel?
    Professional Crastinator
    Reputation: Fleas's Avatar
    As long as your axle matches the dropouts, a smaller wheel should always fit in a bigger fork.
    As far as a bigger wheel in a smaller fork, you might have to provide some very specific wheels/tire/fork combinations to find out here.
    -F
    It's never easier - you just go faster.
    Jul 2013
    I am currently running a 650b fork on my 29er fork and it seems to be working well enough
    B.Ike
    Reputation: ElwoodT's Avatar
    Mar 2011
    In order to keep the geometry the same, you'd have to size down on the 29er fork. Consider a 26 fork that will take a 650b instead.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by yetilover View Post
    You need to proofread you posts better. You can not use a wheel on a wheel or a fork on a fork.
    Also need to know what bike you have.
    If this is a 26" frame you are going to slacken the frame angles quite a bit.
    For the same amount of travel (and the same basic model fork), a 29er fork is about 35mm longer (~2 degree slacker frame angles).
    Add the 650B wheel/tire. Add another 12mm to the front end height (~0.75 degree).
    Total of nearly 3 degrees slacker head tube and seat tube angles. Enough to turn a well handling bike into a wheelbarrow in a sand pit.
    mtbtires.com
    Axle to Crown.....something to keep in mind.
    Jul 2013
    sorry i'll be sure to proofread next time.
    I haven't noticed much change (although I don't think im experienced enough to notice it anyway)
  1. Replies: 5
    Last Post: 03-22-2014, 08:29 AM
  2. Replies: 22
    Last Post: 11-09-2013, 05:19 PM
  3. 29'er Fork with 650B Wheel?
    By myitch in forum 27.5
    Last Post: 08-22-2012, 08:24 AM
  4. Need a rigid fork for a 650b wheel
    By Haystack Calhoun in forum 27.5
    Last Post: 10-09-2011, 01:25 PM
  5. fork offset for 650b wheel
    By peterv in forum 27.5
    Last Post: 07-20-2011, 08:57 PM
Members who have read this thread: 4
