Results 1 to 10 of 10
    MTB B'dos
    Reputation: LyNx's Avatar
    New question here. 2010 Helmet deal, have I already lost 2 years life of the helmet?
    So was looking to get a new helmet as both of mine are now over 4 years old (sticker inside says Dec '06, bought summer '07) and I found a deal on a 2010 version of what I'm looking for, but since it's been sitting in some warehouse for 2+/- years already, have I already lost 1/2 the life of it? Anyone with thoughts or actual knowledge of this?
    Oct 2007
    Helmets are made of a type of expanded polystyrene (aka styrofoam). This material is not really going to degrade if the helmets have been stored inside at regular room temperature, expecially if they are in sealed bags as helmets usually are. Heat and UV light are the main things to worry about.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Typically it's the "in-service" date that starts the clock ticking. Buy it.
    Monte
    Lodging & Guiding for SW Utah Trails
    http://www.vrbo.com/298759
    www.UtahMountainBikingAdventures.com
    MTBR Discounts
    930 is offline
    Quote Originally Posted by STT GUY View Post
    Agreed. UV, petroleum vapors, and typical wear & tear is what degrades the styrofoam. As has been stated before, the helmet was stored in a warehouse in a sealed bag. The degrading of the styrofoam will not begin until it is exposed to outside factors.
    Huckin' trails
    Reputation: David C's Avatar
    Is about any MTB helmets only have a 4 years or so lifetime ? Or is this only for foam helmet, not for skater-style with hard shell over it and full face helmet ?
    Thanks,
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    930 is offline
    Quote Originally Posted by David C View Post
    Thanks,
    David
    The way a helmet works is to slow down the deceleration of the head on impact and reduces the energy transferred between the brain and the skull. To do this, helmets contain a foam the compresses on impact, therefore reducing that energy (think of this way, if you punch a bare brick wall, the energy transferred from your hand to the wall will probably damage your hand. Put some foam over the brick wall and punch it, the foam will absorb some energy, reducing the energy transferred from your fist to the wall and helps reduce/prevent injuries).
    Any helmet, regardless of style (standard bicycle helmet, full face, skate, motorcycle, motocross, hockey, etc), contains foam and should be replaced after a hard hit. Once the foam has been compressed, the integrity of the foam in the helmet is now in question. The foam only compresses once and will not offer the same type of protection on subsequent impacts.
    Hope this helps.
    MTB B'dos
    In other words, if you take a fall/hit that damages the shell of the helmet most definitely replace it, if the shell is not damaged still check the foam if the hit was hard enough, it's done it's one time job probably and time to replace. What he didn't say was that over time sunlight i.e. UV, sweat and the elements start to break down the foam and lessen it's absorption properties and hence although a helmet may look fine, in fact if it took a big hit and had been used regularly for 4 years it most likely would not absorb the impact as well and hence my question.
    In essence if you helmet has in foam, no matter the style then yes, it cannot just be worn "forever" and expect it to actually work when you take a hit 7 years down the line. I can see the foam showing signs of "aging" on my current helmets, they are about 4 years old and hence my search for a new one.
    Quote Originally Posted by 930 View Post
    ............Any helmet, regardless of style (standard bicycle helmet, full face, skate, motorcycle, motocross, hockey, etc), contains foam and should be replaced after a hard hit. Once the foam has been compressed, the integrity of the foam in the helmet is now in question. The foam only compresses once and will not offer the same type of protection on subsequent impacts.
    Hope this helps.
    Thanks,
    David
    There is a huge difference in the types of impacts and how they compromise or do not compromise the ability of the helmet to protect you in the future.
    Helmets have four parts.
    Shell - Prevents punctures and protects the EPS foam.
    EPS Foam - This is what actually absorbs impact energy by deforming and compressing. Helmets use the same EPS. When you buy a high dollar helmet you do not get "better" EPS and in many cases any "better" protection. You (should) get better venting, better adjustment system, upgraded interior padding and some fancy designer dudes graphics and less weight.
    Padding - Takes a tiny bit of the force but is mostly for comfort
    Retention system - AKA strap and adjustment system
    Blunt, high-G impacts are what will compress the EPS (the styrofoam) and when that happens you win but your helmet is toast in the process. Glancing blows which may leave a scrape or scratch on the helmet skin (plastic or kevlar shell) if minor enough do not deform the EPS.
    Bike helmets are extremely easy to inspect (unlike moto helmets where is is very difficult to gain meaningful access to the EPS) so inspect your helmet closely after any impact and if in question I say toss it.
    Monte
    MTBR Discounts
    Plays with tools
    Reputation: customfab's Avatar
    Hope this helps.
    There are helmets out there that use an open celled foam that are not subject to this guideline. All approved bicycle helmets do though. Hockey, football and some skate helmets use this kind of foam and are good until the outer shell has been compromised.
    MTB B'dos
    Don't know about the rest, but yeah the padding in my ice hockey helmet was still good last time I visited Canada end of '09 and the helmet is over 15 tears old, just stored properly when I'm not there. Not sure I'd trust it for a real hockey game, but for some light pick-up I'd wear it, if I can remember how to skate after all these years.
    Quote Originally Posted by customfab View Post
  1. New Helmet every couple of years?
    By BenR in forum Apparel and Protection
    Last Post: 10-22-2009, 09:53 PM
  2. My helmet saved my life (again)
    By JL de Jong in forum Apparel and Protection
    Last Post: 12-23-2008, 09:35 PM
  3. Helmet Life; how long?
    By shades9323 in forum Apparel and Protection
    Last Post: 03-18-2008, 10:39 AM
  4. Helmet Life
    By yucaipaken in forum Apparel and Protection
    Last Post: 10-23-2006, 07:34 PM
  5. a helmet that could save your life
    By Hollis in forum Apparel and Protection
    Last Post: 10-08-2004, 06:07 AM
