Results 1 to 9 of 9
    Reputation: HSracer's Avatar
    Jun 2013
    1x10 Cannondale Scalpel help!!
    So I recently made the switch from 2x10 to 1x10 with my 2013 Cannondale Scalpel 1. I love the drivetrain, but am having chainline issues. Right now, I have the cranks shifted as far left as I can with out the chainring hitting the stay (see picture). Unfortunately, because of the chainline, the chain is rubbing on the outside of the derailleur cage. Does anyone have experience with this or know how to fix it? Thanks1x10 Cannondale Scalpel help!!-imageuploadedbytapatalk1403038040.517108.jpg
    Reputation: 70sSanO's Avatar
    Nov 2013
    Are you using your original 2x crank with one ring removed?
    If so, I guess this wasn't a problem before the conversion.
    John
    1995 Trek 970 - 80mm Atom Race
    1992 Serotta T-Max - 70mm Z3 Light
    1993 GT All Terra - 46mm Mag 21
    (STOLEN)
    Jun 2013
    Quote Originally Posted by 70sSanO View Post
    John
    In the picture I am; however I do have a 1x10 spider from North Shore Billet. The chain line is actually worse with the 1x10 spider.
    No, this wasn't a problem before.
    Reputation: TwoNin9r's Avatar
    Jan 2011
    Quote Originally Posted by HSracer View Post
    Right now, I have the cranks shifted as far left as I can with out the chainring hitting the stay (see picture). Unfortunately, because of the chainline, the chain is rubbing on the outside of the derailleur cage. Click image for larger version.
    shifted to the left meaning you removed the BB and put the spacers on the other side so it would sit as far left as possible?
    also, when you say the chain is subbing on the outside of the RD cage, which side, the inside? (close to the spokes) or the outside? what gears does this happen in? ony the top, only the bottom, or multiple on each.
    there are usually 3 adjustments on a RD, there's the lower limit, upper limit, and body angle. that might be your answer, but i'm guessing if it didn't happen before, the chain line was perfect before and you should return the cranks to the position they were in prior.
    Jun 2013
    Quote Originally Posted by TwoNin9r View Post
    The bb is shifted as far as I can get it to the left. I removed the cranks and added spacers. The chain is rubbing on the side AWAY from the spoke. The chainline was good when it was setup as a 2x10. It has never been good as a 1x10. It runs in the 3 lowest (biggest cogs) gears
    Jan 2011
    yeah. i would put the spacers back exactly where they were, then it should work just like it did before. OOC, why would you move the cranks over?
    Jun 2013
    Ok, I actually fixed it. I'll try to explain it here so that anyone else who wants to do this with their Scalpel can have something to reference. This was done with an X0 2x10 drivetrain.
    Materials:
    1 NW chainring
    1 North Shore Billet 1x10 Spider
    1 5mm bb spacer
    1 X01/XX1 pulley
    First, remove the cranks and put the 5mm spacer on the non drive side (pic 1).
    Next, put the chainring on the new 1x10 spider BACKWARDS with the washer in between the spider and chainring.
    Finally, remove the lower pulley and replace it with an X01/XX1 pulley.
    It mostly fixes the chainline issue
    Jan 2011
    Nice!
    Posted via mobile
    Mar 2012
    Hi, using this old thread to ask a current question that i have (and i am not the only one):
    Has anyone got the measurements to try to convert this into a fsi-AI offset crankset?
    I imagine that it works, by removing the 5mm added and the washers... Has anyone tried?
    The goal is to use the crankset from cannondale 2x10 removing the small ring to use it for f-si with AI offset. The reason in my case is to use the powermeter as there is NO OPTION except Stages (that is not reliable enough for MTB due to water issues).
    Thank you!
  1. Novice question - converting to a 1x10 on a Scalpel
    By Seventh-777 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-05-2014, 09:47 AM
  2. Cannondale Scalpel 3
    By wilkinsdennis in forum 29er Bikes
    Last Post: 11-28-2013, 07:47 PM
  3. Scalpel 29er 1x10 Chain Guide???!?
    By TheYoungConnoisseur in forum Cannondale
    Last Post: 06-29-2012, 09:05 AM
  4. Cannondale Scalpel 29 - What do you think?
    By mud0shark in forum 29er Bikes
    Last Post: 01-13-2012, 04:24 AM
