Results 1 to 5 of 5
    Reputation: RIDIN'MO's Avatar
    Weirwolf on Xcal
    Anyone running the WW 2.55 on Xcal? I have the 09... Will they fit?
    Reputation: byknphil's Avatar
    They sure do. Not good for mud or wet gravel, gums the chain up in no time.
    I tried running them on my 2010 cobia and had problems with rubbing the front deraileur at all but the highest psi. I had to switch out the back with something smaller.
    I've got a BIG 1/16th of a inch clearance is all. Like I said you cant run them in any mud at all because of the clearance problem. I like them in the winter when the gravel is good and froze.
    Same issue
