Results 1 to 5 of 5
    Feb 2006
    Sugar - standard crank fit?
    I have a 02 Sugar 2 that has a compact crank 22-34-42 but I want to swap to a standard 24-36-44, is this a no go?
    That should be fine assuming there is clearance between the chainstay and rings. If not you could use a wider BB spindle to gain clearance.
    Feb 2006
    Quote Originally Posted by ssalmons View Post
    That's the big question, the distance from the two small rings to the swing arm is close and I don't want to push the rings out as the chainline would be off.
    That settles it, time for a new 29er!
    Feb 2006
    Ha! I just test drove a new Santa Cruz carbon highball and it had nothing over my sugar on tight single track and it felt like I was driving a bus. For the trails I ride I like the quickness of the Sugar and my Steel stumpy.
