Results 1 to 5 of 5
    New question here. no more roscoe's?
    Are the roscoe's discontinued for 2011? If you have a frame replacement issue what will trek do? Give you a remedy?
    I hate that name.
    Reputation: blunderbuss's Avatar
    I'm sure they'll have a few Roscoe frames in the warranty department for a little while. Once those run out, I would expect them to give you a choice between an EX or Remedy, although the Remedy would be the logical choice.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Reputation: Trail Traveler's Avatar
    I was wondering about this too. And what about the fork? Think they'd give us a frame and fork or would we have to use the G2 fork off the Roscoe?
    Good questions guys, I was thinking about the same.
    Also what if what is needed is a part of the frame, like a rear der. hanger or any other part that would not require a brand new frame replacement. Will these parts be available?
    I hate that name.
    Both types of ABP hanger should be available from Trek for a long time, and when they no longer are, I'm sure somebody like Wheels MFG will make one.
    The dropping of the Roscoe as far warranties are concerned is no different than any other frame no longer in production.
