Results 1 to 3 of 3
    New question here. How to tighten a main axle on a Superfly 100?
    Hello everyone,
    My friend dropped by today with his beautiful carbon Superfly 100. I took it for a quick spin and realized the tail end was loose. Upon closer inspection it seemed the wiggle was originating from his main pivot axle (the one just above the BB). I wheeled it into the garage, removed his cranks and said WTF?! The non-drive side has the appropriate hex key / socket head to tighten things up, but the drive side is, well its smooth! You tighten the non-drive side and the drive side just spins. Is there some proprietary tool to fix this or am I just missing something?
    Open end wrench and allen both from drive side. No need to remove the crank
    Sent from my SPH-D700 using Tapatalk
    http://Theclydeblog.org Big guy cycling product tester
    I hate that name.
    Reputation: blunderbuss's Avatar
    From the non-drive side, I think is what Duke meant to say.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
  1. Flash Carbon vs Superfly HT or Superfly 100
    By TheTortoise in forum Cannondale
    Last Post: 11-26-2010, 08:33 PM
  2. Superfly 100 axle to crown ?
    By clunkin in forum Gary Fisher
    Last Post: 12-20-2009, 07:24 AM
  3. Superfly Tighten Everything! Update
    By max_cat in forum 29er Bikes
    Last Post: 07-18-2008, 02:33 PM
  4. Superfly Tighten Everything!!!!!
    Last Post: 06-30-2008, 11:29 PM
  5. Replies: 0
    Last Post: 07-21-2004, 06:14 PM
