Results 1 to 6 of 6
    Reputation: jimonthecake's Avatar
    hifi creaks and wobbles
    Hey, anyone ever grab the hifi at the seatpost and the rear wheel and find a lot of play when you shake it side to side? I don't think its my wheel. I tried this on another hifi on the trail last night and his does the same thing. It feels like a loose wheel but its not loose. It also creaks like a pop can constantly.
    Check all pivot bolts.
    Check them for what? I had them off recently to clean the squeaks out and put back together and the play is still there. They are tight enough. Could they be worn out? The play has been there a long time. I just ride through it.
    Reputation: MikeDee's Avatar
    Quote Originally Posted by jimonthecake
    There should be flex but no play. Sounds like you've got worn bushings. My HiFi is pretty new, and there is play at the rear shock mount. Since it's so new it can't be wear but may be the DU bushing or the shock bolt is machined to the wrong dimension.
    Take a good look at the swing arm. That's what mine usually sounds like when it breaks.
    Yep, I'm on my 3rd swing arm. I wonder where I'll be this time when it breaks.
    And I am about to replace the du bushings for 2nd time to take care of the up/down play.
    The side play really sounds like a loose wheel but its not.
