Results 1 to 10 of 10
    HI FI deluxe broken hub. What do I need to do?
    I have a 2010 Gary fisher/Trek hi fi delux 29er with Mustang wheels.
    The other day I was riding and the rear rotor fell off causing one of the bolts to strip the hub out.
    So can I ride it with 5 bolts in it and just leave the 6th one empty?
    I would like to eventually fix it right but have no idea what to do.
    Do I need to buy another hub and have the wheel relaced?
    If so, what hub should I get? Should I upgrade the hub?
    I have already purchased a new rotor and pads so I don't really want to go to a bigger rotor or anything that would cause me to buy a different rotor.
    I definitely will be investing in some lock tight.
    I am very mechanically inclined. I am just new to the cycling / 29er thing.
    So I have no clue which parts are the best or what I need to be looking for.
    Attached Thumbnails Attached Thumbnails HI FI deluxe broken hub. What do I need to do?-imag0826.jpg
    Reputation: drmayer's Avatar
    Quite possibly will be covered under the Bontrager/Trek 5-year wheel warranty, that is if you bought the bike new. If so, take to the LBS and ask.
    Did not buy new
    I would ride with 5 bolts, if you want a new hub Trek website has this listed as original equipment: Shimano M525 SL. You could try to warranty it through Shimano at your LBS, or buy another for $20 or however much a cheap Shimano hub costs. Upgrade to XT hub and forget about it.
    What is an XT?
    If I buy another hub,, I am guessing I will have the wheel respoked correct?
    How much does it usually cost to have a hub replaced?
    Quote Originally Posted by travr6 View Post
    ...I definitely will be investing in some lock tight.
    I would also invest in a torque wrench of the proper range.
    If you replace the hub with the same hub, the spokes could be reused. If you get a different hub, it may require different length spokes.
    edit...XT is a higher level Shimano hub.
    The price of labor varies greatly, here is St Louis I know of a shop that does free wheel building if you buy all the parts from them, and I know of shops that charge $75 or more per wheel. You just need to talk to your local shop, they will fix you up.
    I have a torques wrench.
    If I went with an XT hub would I reuse the same spokes?
    I will call around and see what the prices are on wheel building
    Just to clarify (and forgive me if I'm stating the obvious)...I was referring to a torque wrench to set the correct in/lbs of torque, not a Torx wrench, which is the fastener type.
    Quote Originally Posted by gmcttr View Post
    Yes. The S was a typo.
    Foot pounds and NM
    Anyone know what size hub I would need?
    I was looking up the XT hubs and noticed they come in different sizes.
  1. 08 HiFi Deluxe broken chainstay
    By kimm2222 in forum Gary Fisher
    Last Post: 08-31-2011, 09:36 AM
  2. One20 deluxe or Tanuki Deluxe
    By coqui in forum Kona
    Last Post: 07-17-2011, 05:11 PM
  3. Stab deluxe or Stinky deluxe
    By 3viltoast3r in forum Kona
    Last Post: 10-18-2007, 04:02 AM
  4. 1 fork broken stanchions, 1fork broken steerer. Can I transplant?
    By Johnny M in forum Shocks and Suspension
    Last Post: 05-07-2004, 07:56 PM
