Page 33 of 46 FirstFirst ... 23 29 30 31 32 33 34 35 36 37 43 ... LastLast
Results 801 to 825 of 1137
  1. #801
    Jan 2011
    1998 Tassajara
    My 1998 Tassajara. I haven't seen any on this thread or any where else. I upgraded through the years. Replaced the crappy Indy Shox with Judy Race. Also, new wheelset, Easton Monkey Bars and Stem, Bontrager Race Seat. Otherwise stock. Good old 3x7 drivetrain.
    In it's natural habitat.
  2. #802
    Oct 2010
    GF Paragon I just got last night. Its a 2009 frame that just got warrantied. Basically all new components. Roxshox Recon Silver TK, BB7, shimano deore derailleurs with sram shifters, Bontrager Rhythm Comp wheels and race face atlas bar. huge step up over what I was using before. I love it
    oh and I need to replace those platforms quick. They have no grip and I have a feeling they are going to break soon, made out of plastic. I've got my eye on these: http://www.pricepoint.com/detail.htm...d=240%20DMRV87. Would like to stick with red, compliments the bike nicely. any other recommendations?
  3. #803
    Reputation: Saipanda's Avatar
    I've had good luck with the MG-1s from Wellgo. THey are made of magnesium and are very light and strong too. They come in various colors, including red.
    Long ago when men cursed and beat the ground with sticks it was called witchcraft. Today it is called golf. Will Rogers
  4. #804
    Jan 2011
    Heres a pic of mine in the wild
    Attached Thumbnails Attached Thumbnails Gary Fisher Owners - The Official Picture thread-042-640x455-.jpg
  5. #805
    Mar 2011
    My Superfly 1X9...
    Attached Thumbnails Attached Thumbnails Gary Fisher Owners - The Official Picture thread-sen7003_201104.jpg
  6. #806
    Reputation: JSumner13's Avatar
    My 2010 Rumblefish.....
    Attached Thumbnails Attached Thumbnails Gary Fisher Owners - The Official Picture thread-img_3851.jpg
  7. #807
    Reputation: XRaptor's Avatar
    Mar 2011
    03 Sugar 4+ with upgrades.
  8. #808
    Should've built a bike
    My 2010 Mamba...
    Stock parts remaining - frame, headset, seat, seatpost..yep, that's it.
    Upgrades:
    - Avid Elixir CR brakes with G3CS rotors
    - Fox F29RL 80mm Fork
    - Velocity Blunt wheels with XT Hubs and XT skewers
    - PG-990 (X0) Rear Cassette
    - X9 Rear Derailleur (X0 Mid-cage going on when I convert to 1x9)
    - X9 Trigger Shifters (losing the front when I convert to 1x9)
    - PC-991 Chain (Solid Pin)
    Added 4/25:
    - RaceFace Evolve 175mm Crankset
    - RaceFace Bashguard (Red)
    - Blackspire 32T Mono Veloce SS Chainring
    - N-Gear Jump Stop
    - X0 Mid-Cage Rear Derailleur
    - Rear Tire - Kenda Nevegal (had to lose the FD first)
    - RaceFace Turbine 3/4 Riser Handlebars (Blue - the Fox fork had a 1/2" shorter steering tube than the factory Dart3 did - NOT pictured)
    -Truvativ 90mm stem (not pictured)
    - Crank Brothers Candy SL Rebuild kit
  9. #809
    Reputation: jeremz206's Avatar
    my newly build bike GF tassajara 2009
  10. #810
    Reputation: Hedlund's Avatar
    Mar 2011
    My 2010 Roscoe 2 with some new parts.
  11. #811
    2010 X-caliber
    Here's my Fish: 2010 X-Caliber (17.5 or M)
    2011 Crank Brother's Candy 3s
    Easton EC90 flat bar WIDE
    Specialized Phenom Expert 155 (Ti-Rails)
    Ergon GP1 grips
    Topeak Frame Pump
    Ghetto Tubeless using Gorilla Tape
    Bontrager Seat Pack (conatins my home-made flat pack)
  12. #812
    Quote Originally Posted by tymission
    Ergon GP1 grips
    Topeak Frame Pump
    I noticed you went Ghetto Tubeless using Gorilla Tape.
    What valves did you use (any problems?) and why go Ghetto instead of using the Bontrager TLR rim strips?
    Thanks.
  13. #813
    Gorilla Ghetto Tubeless
    Ghetto cost: $30 Gorilla Tape $8, Stans Presta Valves $12, and Slime Sealant $10
    Shop quote: $80 for the bontrager stems, TLR strips, their sealant, and install.
    So I guess I went ghetto tubeless to save $50.
    So far I haven't had any burps, but I don't run my tires super low, FR- 30lbs and RR-32lbs. I weigh about 185-190. I have been running it this way since April 2nd, 2011 and have only had to top off the pressure once. If you decide to do this, the Duster rims have a deep channel so you will have to do 2 wraps of gorilla tape.
  14. #814
    Thanks for the info and reply (I'll keep your tip for 2 wraps in mind). After your reply I searched and found MTBR threads with video links/info also detailing the ghetto installation process.
    I asked because after numerous attempts, I - and my LBS - were unable to get a secure valve seal on one of my Duster rims using the Bontrager TLR rim strips and valves. (The rim's valve hole was drilled so off-center that the thin Bontrager valve o-ring can't properly seat the tilted valve stem for a secure seal.)
    I thought my only option was to use a Stan's Flow Rim Strip @ $22.50 each (with the integrated valve stem), but now I'll try the ghetto method for a season, since I already have the parts and will use cut-out valves from old tubes.
    Thanks again.....btw, while your shop quoted you $80 for a Bontrager tubeless install, here are the prices of the required Bontrager TLR parts (their quote must have included $30 for labor):
    TLR Rim Strip: $10 each
    TLR Valve: $6.50 each
    Bontrager Super Juice: $20/bottle (more than enough for two tires)
  15. #815
    d2+
    d2+ is offline
    Reputation: d2+'s Avatar
    My first FS bike..
    and the nicest mtn bike i have ever owned..
    Its an 05 Cake 1 and I love it. Mostly stock but it rides great.. Cant wait to throw some money at this bike. The thought excites me..
    Pics up soon..
  16. #816
    Reputation: phoenix417's Avatar
    Mar 2011
    1994 Tassajara
    Just found this the other day at local sale. Nothing modified- looks stock according to the 1994 catalog online. It's virtually spotless- love the old bikes!
    Attached Thumbnails Attached Thumbnails Gary Fisher Owners - The Official Picture thread-gary-fisher.jpg
  17. #817
    d2+
    d2+ is offline
    Nice bike.. here is a pic of what i picked up. Hope to build it up soon.
  18. #818
    d2+
    d2+ is offline
  19. #819
    d2+
    d2+ is offline
    why cant i post a photo?
  20. #820
    d2+
    d2+ is offline
    https://www.facebook.com/editphoto.p...type=1&theater
    here is a link to a pic of mine since i cant post one..
  21. #821
    247
    247 is offline
    In 2008 I bought a 2005 'Paragon' frame and built it up Twice (once in 2008 and again in 2010.) Best Bike I have ever had and finally have it 'dialed in' the way I want it. (RXL stem and post, Salsa Bars, WTB Rocket V saddle, Chris King headset, XT 2x10 crank with bashguard, New REBA fork which increased trail from 38mm to 46mm, Elixer R brakes, Ergon grips, WTB Laser disc wheels--with WTB Lite hubs, Racing Ralph tires, X9 and XT everything else).
    I am 225lbs (down from 260) and this Paragon hasn't cracked yet!!--AND I ride in Central Pa. which has the rockiest and rootiest trails in the country.
  22. #822
    ? i can't upload photo...
  23. #823
    Vitamin Bike Added
    Reputation: MTBCanuck's Avatar
    Bone stock 2004 Tarpon for your viewing adventure. This bike may not be fancy, but rocks the single track. RST 191s are weak but I'll ride them into the ground all day long!
    Attached Thumbnails Attached Thumbnails Gary Fisher Owners - The Official Picture thread-img_1264.jpg
  24. #824
    Reputation: jgboys1's Avatar
    My Cobia chillin at the beach.
  25. #825
    Reputation: TwoNin9r's Avatar
    Jan 2011
    where are all the rumblefish/hifi's!?
