Results 1 to 2 of 2
    DRCV RP2 shock, damper dial stuck
    On my 2009 Roscoe 2. The damper dial is stuck and will only move when I flip the propedal switch. Is this a warranty issue? The shock loses about 10lbs of air after several hours of riding so it needs to be sent back to Fox anyways. Thanks.
    Reputation: Trail Traveler's Avatar
    The dial on my DRCV shock started to get a little sticky earlier this year. A drop of Tri-Flow took care of it.
