    Bontrager seat post angle adustment? It won't budge.
    Got me new Superfly 100 and trying to get it set up to ride. The seat angle is way off, pointing up and the compression fittings that set the angle will not move even after the seat is completely off. Bontrager instructions say to loosen bolts and then try tilting seat while pressing down on the seat. These things won't budge. I'd taking it back to the shop tomorrow but if someone knows a trick it might save me a trip.
    Thanks.
    I hate that name.
    Reputation: blunderbuss's Avatar
    Take the whole thing apart: Remove the outer clampy parts and bolts/spring, if the round wedge pieces don't pull right out, carefully tap them out via the bolt holes. You'll want something thin but blunt ended. CAREFULLY. Tiny bit of grease on the wedges, put it back together.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Quote Originally Posted by blunderbuss View Post
    I kind of was starting along this path just hate tapping on carbon fiber but I'll look around for the right tool and give it another try. Thanks.
    Got it. Its amazing what a hammer and a couple tinker toys can do. Came right out.
  1. Replies: 2
    Last Post: 01-24-2012, 08:46 PM
  2. RIP 9 Seat tube angle: offset post or not?
    By barticus in forum Niner Bikes
    Last Post: 03-23-2008, 02:09 PM
  3. Bontrager Seat Post Diameter
    By Smilerz in forum Vintage, Retro, Classic
    Last Post: 09-20-2007, 10:15 AM
  4. Bontrager Seat Post movement
    By CantClimbOz in forum Trek
    Last Post: 07-22-2007, 03:20 AM
  5. Two bolt seat post - enough angle?
    By TacoMan in forum Downhill - Freeride
    Last Post: 04-30-2007, 01:08 PM
