Results 1 to 5 of 5
    May 2010
    2006 X Cal frame crack
    A guy I work with is getting rid of a 2006 X Cal frame for $100. It has the usual seatpost crack right above the top tube. He is the 2nd owner so he it can't be warrantied. Is this even worth picking up and having the post gusseted like the newer models?
    Moderator Moderator
    Reputation: driver bob's Avatar
    Walk away, I've seen them after the crack splits the intersection wide open and it's not pretty.
    May 2010
    Quote Originally Posted by driver bob
    Thanks for insight. For some reason I knew it couldn't be that easy..
    Moderator Moderator
    If you browse around for deals you can pick up a brand new Access 29er frame for almost the same money.
    I've never ridden one but I've also never seen anything but praise for them..
    http://www.performancebike.com/bikes...7_20000_400314
    May 2010
    Thanks Bob. I guess I should have looked a little harder. That is a great price.
