Page 3 of 3 FirstFirst 123
Results 201 to 238 of 238
  1. #201
    Bro in laws Fuji Reveal 1.0 AM
  2. #202
    Reputation: zeeshan66's Avatar
    Jan 2014
    now that looks serious!
    2013 Fuji Nevada 1.5 D
  3. #203
    Reputation: elliott436's Avatar
    Jul 2014
    Re: Show us your Fuji
    Quote Originally Posted by POAH View Post
    Love the colors
  4. #204
    Jul 2014
    Quote Originally Posted by sehinla View Post
    Hello there. Just picked up my new 2013 Fuji Nevada 1.3 29er. Poor thing sat in my garage for nearly a week until I was finally able to get out on Saturday morning. This is a huge step up from my old Giant Rincon! Love it so far.
    Attachment 875915
    Sweet wheels!
  5. #205
    Jul 2014
  6. #206
    Nov 2014
    My 2012 gran fondo 2.0 with ultegra and mavic ksyrium sl wheelset.
  7. #207
    May 2013
    Tahoe 1.1 with Trax Fattys
  8. #208
    Jul 2014
    My Fuji
    Attached Thumbnails Attached Thumbnails Show us your Fuji-uploadfromtaptalk1419868873255.jpg
  9. #209
    Reputation: powerstroke250's Avatar
    Aug 2015
    Sent from my SM-N910P using Tapatalk
  10. #210
    Reputation: Kartwheel68's Avatar
    Jun 2015
    My two Fujis
    My 2011 Reveal 1.0. 26er I bought it as a bare frame, no shock, on eBay ($305), I added all the components from my hardtail, plus an eBay Monarch R shock ($120) and a NOS 2012 Manitou Minute Pro 120 with a 20mm TA. My wheels are BWW Pure XCR hubs so I already had 20mm adapters. I have only done a few rides on it but I love the bike, its got steeper geometry than the typical AM bike, which I like, but its still very stable.
    My girlfriends Belle 1.0 26er. Its a 100mm frame, I got the frame from the same place but it came with a Monarch RT3 shock and I added Manitou Marvel Expert 100mm QR. She loves it.
  11. #211
    I throw poo
    Reputation: lovemonkey's Avatar
    Jan 2005
    At Mount Black Dog, named for the local bike shop.
    Dang it, now I'm running a coolness deficit for sure.
  12. #212
    Nov 2015
    That's all I've got today :)
  13. #213
    Jan 2016
    New 21" 2012 Outland 3 26er frame from crosslakesales auction so far with new 710mm carbon flatbar, carbon 110mm headset stem + carbon 10mm spacer + lockcap, carbon seatpost, cromo saddle in stock bike blue rail livery (even 'Fuji' printed on seat), at bottom of pic-2 is a K2 Attack 26er chainstay on standby (rdy to cannibalize seat tube pivot point mounting bracket).
    It'll be K2 Attack chainstay at the Seat-tube end and Fuji Seat-stay pivots at dropouts end. Tig welded to extend plus 15mm, for a total 440mm (from crank bb center to rear axle center).
    Project is a 26-to-650b conversion, only need another 15mm on chainstay, 220mm e2e coil shock rear to come. Have a trade in machining and worked in aircraft.
    Note Fox 150 ctd front fork is 27.5 with Hope Pro 2 evo 15mm hub; sue me, going with chinese Carbon rims and shimano Di2 igh rear to be driven off the ht2/bmx 38t ssp crank as shown.
    I'm what, pushing 60 and thinking bowhunt bikepacking to stalk aussie alpine deer - hey, its a thing.
    Looking in woolyhatshop mtb inventory. This project is a pot boiler while I stuff around.
    Sent from my GT-I9507 using Tapatalk
    Attached Thumbnails Attached Thumbnails Show us your Fuji-uploadfromtaptalk1454287073411.jpg
    Last edited by dwmac; 05-01-2016 at 09:27 PM. Reason: Remove 2nd iteration of same image
  14. #214
    Jun 2015
    Definitely keep us updated on how the 650b conversion goes.
  15. #215
    Jan 2016
    You got it, bookmarked so I can oblige as this develops.
    The Fuji chainstay's 'seat-tube' mount locating bolt has to be sleeved in to fit the K2 chainstay's larger seat-tube bracket holes, as the two respective design diameters are not identical spec mates.
    Some light machining and fabrication is required.
    Their actual width difference is K2=66mm; Fuji=68mm: 68 -66 = 2mm. The machined sleeve's major Outside Diameter width (the K2 counterbore shoulder depth + 1mm) should extend to Fuji width for the pivot shaft/bolt. Wider than the K2 by another +1mm per side, to accommodate the main pivot shaft's working length - from head to retaining bolt on crank-side across the seat tube pivot mount.
    The chainstay trail length is another geometry story, and requires the Fuji Seat Stays axle pivots and dropouts to remain, but not the K2's. Some of the original Outland 3.0 chainstay fabrication will remain after tig work at that axle end. But not much, just the very tips with the seat-stay pivots.
    650b wheelsize conversion must give an estimated eye-to-eye horizontal dimension of 39cm (between chainstay ends' center-to-center). The Seat Stays will extend 19-20mm with a 216mm eye-to-eye rear shock. This will still clear the seat tube. Currently 196mm rear suspension.
    This geometry arithmetic is a comfortable +15mm to chainstay length; a crank-to-axle extension from 425mm (for 26er) to 440mm. New rear shock length of 216mm e2e is +20mm to Seat-stay. So the static resting axle height and the crank height should stay on a fairly level keel.
    29er chainstay length is 450mm from crank to rear dropout. Crank to Seat Tube pivot point center is -25mm, and chainstay trail length from the Seat Stay pivot bearing is another 25mm to the rear dropouts. 45cm minus 5cm = 40cm (29er geometry). That indicates what the subframe length needs to be and what the hardpoint dimensions are.
    A 19.1mm longer rear shock still leaves some e2e clearance room without hitting the frame seat tube, and preserves some rear triangle angle geometry, through changed bb elevation, once the larger wheelsize swaps in.
    My L/R custom sleeves will employ trade hire machine shop services (I don't have a shop), the work is a teensy job.
    Apologies for the post hoopla. Making sense was pretty tough.
  16. #216
    Nov 2015
    Getting its shape.
    After long time of part collecting, bike is starting to be reality.
  17. #217
    Nov 2015
  18. #218
    Nov 2015
    I think it looks nice. Under 1k $
  19. #219
    Apr 2005
    Just picked up a closeout 2012 Outland 1.0 29er
    Added Continental Race Kings F/R, Shimano Saint pedals and a Cateye Stealth 50 GPS computer.
    29er is quite the upgrade from my old 90's GT
    Attached Thumbnails Attached Thumbnails Show us your Fuji-20160218_011022194_ios.jpg
  20. #220
    Nov 2015
    Quote Originally Posted by rm25x View Post
    Did you buy online?
  21. #221
    Apr 2005
    Quote Originally Posted by jazu View Post
    Did you buy online?
    Yeah, got it from Jenson USA. It was the last one they had and just happened to be in my size.
  22. #222
    Bought the frame (2009 Reveal 2.0) NOS a few years ago online (ebay). Built it up with mostly new parts and some old parts.
    Attached Thumbnails Attached Thumbnails Show us your Fuji-20140508_171535.jpg
  23. #223
    Jan 2016
    2012 Outland wheelsize Project update: K2 Attack chainstay mod. Pic1 2012 [ATTACH]Fuji Outland[/ATTACH] showing chainstay mod.
    My rough shop drawing: Pic2 [ATTACH]Sleeves[/ATTACH]
    Attached Thumbnails Attached Thumbnails Show us your Fuji-uploadfromtaptalk1462162182188.jpg
  24. #224
    It's a real bummer your bike got stolen, man.
    That said, I think Fuji should start making all entry level bikes with rigid forks (probably steel). It's a lot more predictable than the old coil spring dealy that came with the bike.
    That and the wheels it came with... Other than that I can't complain about this bike. Since both have been replaced I'll just stop now.
    I never came back here to update, but my Fuji and my Spec RH were recovered in Aug 0f 2014. I sold the Spec to offset the cost of replacing my roadbike, but the FUJI lives on! I had to replace a few things as it got beat up pretty bad, but, yeah, she's safe and sound in the garage.
  25. #225
    NDD
    NDD is offline
    Baby boy
    Reputation: NDD's Avatar
    Jul 2013
    Quote Originally Posted by Bammers View Post
    Wow! Glad to hear it.
    dang
  26. #226
    Jul 2016
    Need help IDing this bike !
    Can anyone help me identify this? It would be my first venture into full suspension wondering if it is upgradeable. I know FUJI makes great roadies and hybrids and this looks decent to me but any input would be great ! Only model i can find on bike is OSX 1000 and i cant find anything on that.
  27. #227
    MTBR Member
    Reputation: ncfisherman's Avatar
    It's a 2000 Fuji Diamond 1 -- 2000 Fuji 1 Diamond - BikePedia
    I'd only suggest buying it if it were super cheap and you plan to ride it as is. IMO, it's not worth putting any significant money into and the money would be better spent on a more recent model year hardtail.
  28. #228
    Jul 2016
    Built two Fuji bikes last fall after convincing my wife to upgrade from her Motobecane 400HT to a proper dual suspension higher quality bike. Bought a 2012 Belle 1.0 and a 2009 Outland RC frame off of eBay, got each for under $300. Then I build them up to match, mostly. The main difference is the Belle has a Rockshox Reba RLT and mine has a SR Suntour Epixon with remote lockout. Other than that the build was basically identical. WTB tires, BWW wheels, full shimano M610 deore(upgraded to SLX 2x cranks), Avid Elixir brakes then just using your generic Oval or what not for the stem, seatpost, handlebars etc. Took a bit to get it fit for her, but she loves the bike and it weighs in at 27lbs. My outland is about a half pound lighter and the thing flies up and down the mountains. Loved to build these and we both feel pretty good for what we got for about $3200 for both bikes.
    Show us your Fuji-img_20150919_194251667.jpgShow us your Fuji-img_20151023_175538723.jpgShow us your Fuji-img_20151012_101001986.jpgShow us your Fuji-img_20150919_194156278.jpgShow us your Fuji-img_20150926_212556933.jpg
  29. #229
    Aug 2016
    Just bought a 2012 fuji nevada 2.0 on ebay its a 26er with a 23" frame. Considering im only 5'6", i need to change the frame so i bought a fuji outland 2.0. Still need to fix now im selling the nevada frame with the crankset alivio, and prob with the fork cause the outland needs a tapered fork
  30. #230
    Jul 2016
    2016 Nevada 1.7 29er
    Multiple upgraded bits
  31. #231
    NDD
    NDD is offline
    Baby boy
    Jul 2013
    Quote Originally Posted by bellnghmrider View Post
    Lol! I did the exact same thing, except I have a model year earlier. It's my commuter/offroad bike now.
    dang
  32. #232
    Jul 2016
    Nice looking rig you got there!
  33. #233
    Jul 2016
    Yesterday's romp on the mountain...
  34. #234
    Apr 2016
    old but not forgotten
  35. #235
    NDD
    NDD is offline
    Baby boy
    Jul 2013
    Quote Originally Posted by bxlunltd View Post
    Nice!
    dang
  36. #236
    Reputation: DubzOxford's Avatar
    Nov 2012
    My Fuji Cross / Gravel Grinder
    Attached Thumbnails Attached Thumbnails Show us your Fuji-fullsizerender.jpg
    Fat and Single
  37. #237
    Mar 2017
  38. #238
    Jul 2017
    So I received an old mountain bike for free. I haven't ridden off-road but now that i have a bike i might try. The rear shock holds air but front fork (RST 381 el) might need replacing. I will be looking to do some low budget upgrades.
    2001 Fuji Diamond Lite-1
    Weight:30.5
    Colors: Red/white/blue
    Wheels and Tires
    Hubs: Front: Fuji aluminum, Rear: Shimano Alivio
    Rims: Alex DM-18, 32-hole
    Tires: 26 x 2.00inch
    Spoke Brand: Stainless steel, 15g
    Components
    Brakeset: Tektro 829A brakes, Tektro 379A levers
    Shift Levers: Shimano Deore RapidFire SL
    Crankset: TruVativ 5D, 22/32/44 teeth
    Pedals: clipless (no shoes)
    Bottom Bracket: Sealed cartridge, 115mm spindle
    BB Shell Width: 68mm English
    Rear Cogs: 9-speed, 11 - 32 teeth
    Seatpost: Fuji Micro adjust, 26.8mm diameter
    Handlebar: Fuji aluminum
    Handlebar Stem: Fuji
    Headset: 1 1/8inch threadless Dia-Compe STS
Members who have read this thread: 10
