Results 1 to 9 of 9
    Pedal Force & FUJI carbon Frames
    Hi,
    I just realized that Pedal Force MT carbon and FUJI (new 2008) carbon frames share the exact same specs...
    also, the frame itself looking at the pictures looks identical..
    are they both the same? made on the same place? (on pedalforce website they say that their frame is produced by the same factory used by many big brands)
    here is a comparison:
    geometry specs ARE THE SAME on fuji's site and pedalforce's site!
    anyone can compare can side-by-side to be sure?
    Nov 2007
    Well, if they are not the same, they sure look are the same !
    So, how good or bad are Fuji Carbon C7 & C4 Frames ?
    the top tube and head tube look a little different...
    Nov 2007
    There is slight differences depending of PedalForce frame size :
    Personally, i believe that they are the same as Fuji Frames...with one difference...no graphics
    Reputation: Oxygen's Avatar
    Dont think I could ever go a Fuji....that has Simply Better stamped on the cross tube.
    Perhaps this sells them in the east though?
    Fuji frames have no v-brake bosses, so they are not the same frame.
    1 bike per day + 1 or 2
    Hey that is my PF MT build that is posted here. Who said you could use it.
    I like the frame and was thinking that they are very very close to the Fuji frames.
    Quote Originally Posted by bdc88
    I'm sorry for not linking the owner, i didn't remember your username but had the url saved.
    Your build is really nice btw.. do you know the weight?
    I was totally giving you a hard time which is hard to get across by email and postings. I am totally fine with the picture being used in this manner.
    Here is the information on my build and my SS build.
    BIKE: PEDAL FORCE MT XC
    BOTTLE CAGE: Planet bike 24g
    BOTTLE CAGE BOLTS: Syntace 4g
    BOTTOM BRACKET: Token 68 X 108 148g
    BRAKE LEVERS: KCNC VB1 V-Brakes and lever kit 286g
    BRAKES REAR: See levers
    BRAKES FRONT: See levers
    CABLES/HOUSINGS: Standard housings at this time 140g
    CASSETTE: TOKEN 11/32 154g
    CHAIN: KMS X10SL silver with links missing 240g
    CRANKSET: FSA Team Carbon 433g
    - CRANK ARMS:
    - BRANK BOLTS: Token aluminum bolts 9g each 18g
    - OUTER RING: Extralite 44t 60g
    - MIDDLE RING: Extralite 30t 28g
    - INNER RING:
    - RING BOLTS: Extralite 1.2 4g
    DERAILLEUR FRONT: XTR 127g
    DERAILLEUR REAR: XTR tuned with carbon cage and ti spring 175g
    FORKS: Sid Team Cut to size 1426g
    FRAME: Pedal Force MT carbon HT 1143g
    GRIPS: ESI silicon 51g
    HANDLE BAR: Easton EC90 SL 99g
    HEADSET: Pedal Force Supplied 81g
    HEADSET CAP/BOLT: Syntace Cap, standard bolt and compressor 30g
    HEADSET SPACERS: Carbon Spacer 20g
    PEDALS: Eggbeater SL 268g
    QUICK RELEASES:
    SEAT: SLR Carbonio 160g
    SEAT BINDER: OmniRacer 34.9 10g
    SEAT POST: KCNC Ti Pro Lite 31.6 X 350 155g
    SHIFTERS: XTR 217g
    STEM: Syntace F99 25.4 105mm 108g
    TIRE FRONT: Maxxis Minatour 465g
    TIRE REAR: Maxxis Minatour 464g
    TUBES: Maxxis UItralite tubes 108g eash 216g
    WHEEL FRONT:
    WHEEL REAR:
    WHEELSET: American Classic MTB 350 1452g
    MISC OPTION:
    TOTAL WEIGHT IN GRAMS: 8206g
    TOTAL WEIGHT IN POUNDS: 18.09lbs.
    BIKE: PEDAL FORCE MT SS
    AEROBARS:
    BOTTOM BRACKET: Kult 68 X 108 155g
    BRAKE LEVERS: Extralite Ultralevers 64g
    BRAKES REAR: Vuelta Mag Tuned 116g
    BRAKES FRONT: Vuelta Mag Tuned 116g
    CABLES/HOUSINGS: Aztec Powercord 80g
    CASSETTE: Single 16T Shimano Cog and spacers 100g
    CHAIN: KMS X10SL silver with links missing 212g
    - CRANK ARMS:
    - BRANK BOLTS: FSA aluminum bolts 11g each 22g
    - OUTER RING: Custom Fibre-Lyte Carbon 32t 51g
    - MIDDLE RING:
    - INNER RING:
    - RING BOLTS:
    DERAILLEUR FRONT:
    DERAILLEUR REAR: Surly Singulator c/w carbon upgrades 110g (this has been changed to a new design and is 90g now)
    FORKS: Trigon Carbon Fork 475g
    HANDLE BAR: Easton MonkeyLite SL 135g
    QUICK RELEASES:
    SEAT: SLR 150g
    SHIFTERS:
    TIRE FRONT: Maxxis MaxxLite 310 310g
    TIRE REAR: Maxxis MaxxLite 310 311g
    WHEEL FRONT: Specialized S-Works wheel and rim strip 661g
    WHEEL REAR: Specialized S-Works wheel and rim strip 778g
    WHEELSET:
    MISC OPTION:
    TOTAL WEIGHT IN GRAMS: 6389g
    TOTAL WEIGHT IN POUNDS: 14.09 lbs.
