    Nevada 1.0 handle bar
    Being new to riding I have a question. I need a bar with a little more rise in it. Yet after looking at all the options I notice there are different clamp sizes, which I would guess this means there are also different bar diameters. Would any of you know the diameter of a bar that would work on my nevada 1.0 2009 model?
    Thanks Jim
    MTBR Member
    Reputation: ncfisherman's Avatar
    I believe the handlebar diameter is 25.4 on that. It should either be 25.4 or 31.8 and either the stem or bar(maybe both) should be marked w/ length & diameter.
    fuji bar
    Neither the bar or stem is marked. Using a straight edge placed near the stem connection under the bar, then sighting across it appears to be 25mm. I also tried fitting the seat post (which is marked at 27.2) into the bar clamp and it was too large for the clamp to accept. So, would my thinking be correct by assuming it's a 25.4 as you stated earlier?
    Again Thanks, Jim
    MTBR Member
    Yeah, it's a 25.4
