Results 1 to 3 of 3
    Reputation: adamant118's Avatar
    Nov 2008
    how can u tell what year bike was built
    its a Fuji outland pro full suspension .
    MTBR Member
    Reputation: ncfisherman's Avatar
    Post a photo and maybe someone could help you out.
    Reputation: damnitzhym's Avatar
    Quote Originally Posted by adamant118
    Is the rear shock mounted inside the front triangle or behind it above the rear wheel? The former is 2007-present, the latter is 2006. I believe earlier than 2006 they were called Diamond rather than Outland. At least that seems to be the case with the case with the RC; not so sure with the Pro or Comp.
