Results 1 to 3 of 3
    Willard
    Reputation: willbarrow81's Avatar
    Hello there, Im wanting to change my tires from stock...
    Anybody know what the max tire size a 2010 fuji 4.0 will take? Im looking at 26x 2.3 right now.or if you knew where I could look it up at. Its the V-brake model with an option to put disk on. Ive been looking, but nothing is comming up. Thanks for the info! Later, Will.
    Fuji Nevada 4.0 W/Surge hard forks. I sit very up-right due to my back injury.
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    2.3 should probably work
    The bike comes standard with 2.1 tires, so a 2.3 should probably work, depending on the tire you buy. I doubt you'll find any info that specifically tells you the maximum tire size, because not all tires of the same "size" have the same measurements. You may want to check with the shop where you purchased the bike.
    BTW, why the need to replace the tires with larger ones?
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Willard
    Im a really heavy guy and it feels soooo much better on fatter tires. Thanks for the info, lbs says up to 2.5 should work. We will see! Later, Will.
  1. wanting to change stem out need help on size
    By bhigdon101 in forum All Mountain
    Last Post: 07-16-2010, 11:33 AM
  2. Replies: 1
    Last Post: 03-28-2010, 10:09 AM
  3. I'm wanting to change my rubber, + BIKE CHECK
    By ryan_daugherty in forum Downhill - Freeride
    Last Post: 11-23-2007, 04:57 PM
  4. wanting new tires
    By archybiker in forum Wheels and Tires
    Last Post: 06-28-2006, 10:10 PM
  5. Wanting to but new tires
    By gibbyk in forum Wheels and Tires
    Last Post: 10-26-2005, 10:28 AM
