Page 6 of 7 FirstFirst ... 2 3 4 5 6 7 LastLast
Results 126 to 150 of 160
Thread: Your bikes....?
  1. #126
    sandbagger
    Reputation: airmiller44's Avatar
    My personal prototype
    V10.5 with Dorado pro and Vivid Air
    TWOSIXBIKES DJ prototype
    Www.twosixbikes.com
    www.facebook.com/twosixbikes
  2. #127
    ^That looks like Fun, with a capital F!!!
  3. #128
    Feb 2013
    Here are a few pictures of my "Freddie" MTB I made in the late 90's. I started building bikes with Freddie in 92-98 we made around 100 bikes mostly road frames for local racers.
    I made this frame from Ritchey Logic tube set. It had Campagnolo Record OR components and a Manitou3 fork when it was made. A couple years later I sold the Manitou and made this fork and started using the stem pictured here. I just replaced the Campy headset with a King, built the front wheel and added posts for the caliper on the fork for disk brakes. Next I am working on a front suspension like the Look Fournales or Proflex.
    Your bikes....?-img_20130308_175223%5B1%5D.jpgYour bikes....?-img_20130308_175317%5B1%5D.jpgYour bikes....?-img_20130308_175400%5B1%5D.jpg
  4. #129
    Reputation: uncle_bob's Avatar
    It ain't Mountain
    I know it's not mountain, but I built it and it's fun to cruise.
  5. #130
    ^ I'd be afraid that someone I knew would see me riding it.
  6. #131
    Reputation: toby_g's Avatar
    I have been meaning to post up my bike for a while now. I think I have enough posts to do it
    It is Fillet Brazed Columbus Zona.
    26" Wheels.
    69* Headangle.
    595mm ETT. (665 Front Centre)
    400mm CS
    120mm Reba Fork
    XT Gruppo
    (I didnt get the cable routing right on this one, but I learnt a lot, and the next frame I made, was very similar, but with a 44mm headtube and good cable routing for a 1x10 drivetrain)
  7. #132
    May 2013
    ^ beast!
  8. #133
    Jan 2011
    My new single speed 29er setup for gravel grinding.
    It is very similar to my other bike. 29er with short chainstays and running single speed. Heres a photo of it setup with a rigid fork, crazy 48/22 gear ratio, and some dust after a gravel grinding ride.
  9. #134
    Moderator Moderator
    Reputation: Walt's Avatar
    That looks great! What's the geometry? That tire is CLOSE to the seat tube!
    -Walt
    Waltworks Custom Bicycles
    Park City, UT USA
    www.waltworks.com
    waltworks.com/blog/
    instagram.com/waltworks/
  10. #135
    Jan 2011
    Thanks Walt!
    The angle of the photo makes the gap look a little bit tighter than it really is. I am running a half link and in the photo the sliders are slammed. It's tight but clearance is good with 2.1 tire and 48 tooth ring.
    The geometry is typical "race inspired" 29er with 71/73 angles and 60mm of BB drop. Effective top tube is 598; Front center is 649. Chainstay length is 434 with the sliders all the way forward.
  11. #136
    Just finished building a Prototype Steel 29er. Columbus Zona 29er tubeset, Fillet brazed. 44mm HT Length 120mm. 68 Head Angle, 73 Seat Angle. 440mm Chainstays, 50mm BB Drop. 120mm Rock Shox Revelation. XT/SLX Gruppo. Easton Haven Bar/Stem/Wheelset. Reverb Seatpost. Ritchey Saddle. Conti X-King Tyres.
  12. #137
    Feb 2013
    Not a mountain bike, but my 3rd frame.
  13. #138
    My first frame (non mtb)
    Built this for the boss as a retirement present so he can smoke cigars and pick up cans on side of the road. lugged, skinny tube townie. rides so much smother than my merlin road bike. tubeset for 29er should be here Friday for the next build. then a 26er single, then a road bike. then.............
    thanks to everyone for their inspiration to try and build cool shit. that's what its all about.
    Sean
  14. #139
    Really nice. Did you use a seatube lug/sleeve? Looks like seat stays attach to top tube.
    Great job.
    I was referring to Toby-g's blue 29 er at top of the page. Sorry for misplaced post
    Sean
  15. #140
    My test mule
    I figured I would make my 1st post here one of my Carbon test bike that I built last winter. It has done very well, and far exceeded all my expectations this year. It is a hand laid carbon frame with Aluminum inserts for the headtube and bottom bracket.
  16. #141
    Quote Originally Posted by sxconway View Post
    Great job.
    Sean
    Yes, I used a sleeve, and attached the seat stays to the TT; well they intersect both the ST and TT, in order to get the clearance I wanted for 2.4 tyres. Don't ask how I did the mitre, it was done by hand, and only took about 2 hours ( for the right side, then used a mirrored template for the left).
  17. #142
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Well done Toby. I like that you saw and worked through this problem and come up with a clever solution, stylish too.
    Eric
    If I don't make an attempt, how will I know if it will work?
  18. #143
    frame 014
    May as well share with the class. Here's a 29r+ knard tired bike. Tig welded 853/nova ex-butt ST/Deda 29r CS with a home made drive side yolk:
Size:  23.3 KBName:  11076724684_7a5a7de6fd_m.jpg
Size:  22.0 KBName:  12182564095_d734c21c07_m.jpg
    frame is blasted and Nyalic'd no paint
    cheers
    andy walker
    Walker Bicycle Company | | Walker Bicycle Company
    Flickr: afwalker's Photostream
  19. #144
    Reputation: Maroof's Avatar
    May 2014
    looks damn good!
    Quote Originally Posted by zank View Post
    I missed not having a mountain bike for the past 5 or 6 months.
    IMG_0002 by Zanconato Custom Cycles, on Flickr
    2013 Trek 4300
  20. #145
    Reputation: MiWi's Avatar
    Jan 2013
    My quite aggressive 29er Trailbike
  21. #146
    Dec 2008
    Lugged 26er
    Old school lugged 26er.
  22. #147
    Dec 2008
    lugged 26er
    lugged 26er
  23. #148
    Reputation: adarn's Avatar
    Here is the MTB I built myself this spring. I did some geometry experimentation with it, and while I will change some things on the next one, It is a ton of fun:
    I built it for a SS race I did along side the Sklar Bikes Factory Team. It's way less cool now and has ten whole gears.
    And then I built myself this cross rig at the end of the summer to race in the fall. I like cross a lot and I like this bike too. Also good for shoulder season training rides.
    Cyclocross by SklarBikes, on Flickr
    -Adam Sklar
    My blog
    Instagram
  24. #149
    #26aintdead
    Just finished this rad little Hardtail, with 26" wheels
    funny story: my sister was looking for a new MTB, but all the big brands now no longer do 26" hardtails, (*with a decent spec, they do have a couple, but usually in the <£300 range). So she decided to go custom, I had a lot of fun doing the road bike for her earlier in the year, as getting the fit right was a good challenge, so was happy to oblige with the MTB. Budget was tight, so a lot of Workshop spare and old parts were used. I future proofed the thing with internal cable for a dropper post, which she intends to purchase once she had recovered from the big hole in the wallet the frame burned.
  25. #150
    Reputation: dump's Avatar
    Lovely work toby_g... your sister should be very happy to ride that!
