Results 1 to 6 of 6
    Aug 2018
    XXL Frame - Tubing Thoughts
    I've done some forum searching, but I haven't come up with much info that's applicable.
    I'm a hobby-builder (building for myself only). Nothing fancy; hacksaws, files, and a drill press, fillet brazed 4130 frames, homemade 80/20 fixtures.
    I'm starting to plan my 4th frame. The first 3 were a fat bike, a mid-length cargo bike, and a 27.5 Plus MTB.
    For the first 3 frames I used these non-heat treated 4130 tubes:
    • DT: either 34.9 or 38.1, .9/.6/.9
    • TT: 31.8, .9/.6/.9
    • ST: either 28.6 or 31.8, .9 straight gauge, sleeved at seat cluster
    Thing is, I'm 6'7" and 230lbs, and I like longer head tubes and relatively horizontal top tubes. All my frames have had (and will have) really big front triangles with eff TT lengths around 660mm, ST lengths in the 590-610 range (c-c) and 185-200mm head tubes.
    Frame #4 is another fat bike, and I was planning to use these non-heat treated 4130 tubes:
    • .9/.6/.9 for the 38.1 DT
    • .9/.6/.9 for the 31.8 TT
    • .9 SG for the 31.8 ST (sleeved to 34.9 at ST cluster).
    But now I'm second guessing myself... for my height, weight and frame size, should I also be using .9 straight gauge for the DT and TT?
    Interested in what more experienced builders think...
    Reputation: Clockwork Bikes's Avatar
    Look at Vari-Wall's offerings like this: https://shop.vari-wall.com/Steel-Tub...81171s-285-02/
    Or find some True Temper Supertherm 1.1/.7/1.1
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    Aug 2018
    Quote Originally Posted by Clockwork Bikes View Post
    Thanks Joel. I've stayed away from heat treated tubes since I'm doing everything by hand (files and hacksaw). How is the Thermlx to work with?
    It's not bad at all. You just want to avoid the super hard stuff like XCr or 953.
    Moderator Moderator
    Reputation: Walt's Avatar
    Straightgauge won't be any stronger - you're not going to break the tubes in the thin/middle sections anyway.
    If you're not a crazy hucker, and your existing bikes are holding up, you could certainly stick with what you have done before.
    If I were building you a frame, I'd use Vari-Wall tubes like Joel mentioned in 1mm wall thickness. But I'm paranoid (and building stuff for people who aren't me). You're probably fine to keep doing what you've been doing.
    -Walt
    dru
    dru is offline
    You'd mentioned files and a hack saw. Do you own a Dremel? I've built two frames using OX Platinum and the Dremel is a godsend. A junior hacksaw cuts just fine btw. I needed to do a bit of filing on the brass but nothing on the miters. A Dremel does amazing things.
    occasional cyclist
  1. Replies: 2
    Last Post: 09-30-2016, 01:46 PM
  2. Replies: 1
    Last Post: 07-27-2015, 06:37 AM
  3. Replies: 0
    Last Post: 08-26-2014, 11:24 AM
  4. XXL Sizing vs XXL Tallboy?
    By slipstream in forum Turner
    Last Post: 09-05-2013, 07:16 PM
  5. Replies: 3
    Last Post: 05-27-2008, 05:50 PM
Members who have read this thread: 48
