Results 1 to 40 of 40
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    Well.....frame number 5
    I got a crazy idea to build another 36er go figure this ones going to
    be aluminum!!!
    Well.....frame number 5-dsc00521.jpgWell.....frame number 5-dsc00522.jpgWell.....frame number 5-dsc00523.jpg
    PAYASO 36er.....Live the Circus
    MR. 36er TROLL
    I'm sorry what part of "BIGLY" didn't you understand?
    pvd
    pvd is online now
    Reputation: pvd's Avatar
    Where's the print?
    WIGGLER
    Feb 2007
    Quote Originally Posted by pvd View Post
    Where's the print?
    Print? I can barely type with two fingers! No blueprint or front center calculation (even if I knew what that was)
    I just throw tubes in a jig and get to cracking!!
    MR. 36er TROLL
    pvd
    pvd is online now
    You may find that your results will improve dramatically with some prior planning. Think of the five p's.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Todwil
    Like to share how you bent your tubes, and what grade aluminium you are using?
    Looks good. I presume that you are making a duplicate frame of what you have already made out of a different material? Tick the alloy box, then TI next....
    Have fun
    Eric
    If I don't make an attempt, how will I know if it will work?
    Way to go Todwil, I love it, keep freakin' everyone out.
    Like you say, live the circus
    Reputation: D.F.L.'s Avatar
    I think you're gonna put a hurtin' on those poor AMP pivots.
    I bought a pristine AMP fork, long ago, to shorten, not lengthen (;
    WIGGLER
    Feb 2007
    The tubes are bent the same way as before JD2 for the ST/CS and the
    HF roller bender for the DT/TT/ST all the tubing .065 except the ST and
    May be changing this because it bent weird at the butts. I don't believe you have to do a schematic for one offs or for personal use 'cause your going to ride it anyway it turns out and to date I haven't made one the same on purpose.
    The AMP fork is doing better than I expected. The only change I would
    Like to do if I was making the fork would be sealed bearings and just a
    Little beefier for a better warm fuzzy when rippin' downhill!
    Ive been an oversized clown my whole life!
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    Well head tubes just got back in stock at Nova so I should have new pics soon!
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    Well it's been a while and I haven't done much on this but just got some different dropouts for this and I just started finishing up the bending and dimpling the CS's
    Ill post pics tonite or tomorrow.
    After dimpling the CS does anyone ovalize the tube from dimple to the bottom bracket
    And if you do you just press it or do you use a die of some sort? I'm thinking on ovalizing the round tubing by just pressing it a little
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    Update Pics
    Here are the updated pics my first change was the BB shel the Nova one was about 4mm narrower than the Niner and the eccentric is super sloppy so sloppy that if this was a piston and cylinder it would need a bore job so I ordered a Niner one its the same width as the steel one so no setup change. The next was the rear drops the Kavik ones seem stronger. The next is CS dimpling to gain clearance and a little shorter CS length.
    Well.....frame number 5-dsc00677.jpgWell.....frame number 5-dsc00678.jpgWell.....frame number 5-dsc00679.jpgWell.....frame number 5-dsc00680.jpgWell.....frame number 5-dsc00681.jpg
    MR. 36er TROLL
    Harrumph
    Reputation: G-reg's Avatar
    What shell are you using with the 9er Ebb? I thought they didn't use a "standard" width or inside diameter?
    Slowly slipping to retrogrouchyness
    WIGGLER
    Feb 2007
    I'm using Niner brand shell and they have several styles of inserts, EBB, BB30 and I think they have or had one centered threaded.
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    Sundays effort
    Here is some pics of todays copin tubes!
    Well.....frame number 5-dsc00682.jpgWell.....frame number 5-dsc00683.jpgWell.....frame number 5-dsc00684.jpg
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    Closer
    Here's a couple more pics, I had a seat post slug made from 1-1/2 .125 aluminum turned down to except a 34.9 clamp.
    MR. 36er TROLL
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey...
    I'm seeing serious craftsmanship going on here! What gives?
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    WIGGLER
    Feb 2007
    6061 and counting
    Here's a couple more from today!!
    Here's one for Trailmaker these are my hi-end coping tools!!
    MR. 36er TROLL
    Nemophilist
    Awwwww,.... MAN;
    My illusions are totally blown....
    WIGGLER
    Feb 2007
    Nut-zerts
    Has anyone used nutzerts for water bottle cage? I been looking
    At new bikes and they look like that's what there using.
    MR. 36er TROLL
    Nemophilist
    Yes;
    They are working fine. I would say that I'd want a real good quality type, and with a fairly large flange for added grip. I've used them plenty on other things and have had some issues with the small flange "invisible" type not staying in place and spinning. This will be ESPECIALLY problematic on such thin wall tubing. It might not even be a bad idea to install them with some epoxy on them!
    WIGGLER
    Feb 2007
    Thanks I see that Nova has them but no tool I may skip it on this one.
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    I added a seat stay holder to my jig.
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    I did some tacking and welding. Also couldn't help myself, I did the
    classic Payaso test fit!!! 'O and some pics!!!
    MR. 36er TROLL
    are you planning to have it heat treated?
    WIGGLER
    Feb 2007
    The short answer is no. The long answer is no because it will come back to a T value
    on its own "age harden" and this I didn't know was it will do this fairly quickly a couple of weeks. The HAZ areas will never be back to T6 without chemical heat treating but they can come back to T4-T5 the rest of the unaffected parts are still T6. The next frame I do will be 7005 series Aluminum. I stopped on this project for a while to research this and also change a few parts and I now feel comfortable continuing.
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    Got a little further today. Couple more welds and it'll be done!Sorry about the pics better ones tomorrow.
    MR. 36er TROLL
    Nemophilist
    Truly EXCEPTIONAL style. The subtle curves are perfection.
    WIGGLER
    Feb 2007
    Thanx I can't wait to ride it!
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    30lbs
    OK Im tired here some built up picks I haven't ridden it on the trail yet
    ride report tomorrow. Changes from last frame.
    80mm headtube
    Niner EBB
    Kavik replaceable dropouts
    525mm CS
    Well.....frame number 5-dsc00695.jpgWell.....frame number 5-dsc00696.jpgWell.....frame number 5-dsc00697.jpg
    MR. 36er TROLL
    Harrumph
    Looking good Tidwell, did you fab that fork? What are the #s?
    WIGGLER
    Feb 2007
    Thanx
    Quote Originally Posted by G-reg View Post
    Thanx G-erg The frame weighs 3.9lbs as you see it and the
    fork is 3.0lbs.
    71.5* head angle
    73* seat tube angle
    12.5-12.750" BB height
    522mm chain stay length
    25" TT length
    770mm FS
    49.5 wheel base
    29.86lbs as it sits right now
    I rode it last night I had a few gremlins I broke a spoke in the front and back wheels and the rear brake was dragging not bad but it sounded like I was bugeling for Elk. Couple new spokes and some
    brake shims and round two tonite.
    MR. 36er TROLL
    Harrumph
    Ha, cellphone typing...
    Are those #'s adjusted from previous Payaso's, or same #'s but done up in Al?
    WIGGLER
    Feb 2007
    No worry's I figured your computer was helpin ya spell mine does all the time. The angles and BB height are the same the CS are shorter,
    the front center is longer, the HT is shorter.
    12 miles on it no gremlins tonite more to come....
    MR. 36er TROLL
    WIGGLER
    Feb 2007
    60 Miles
    Well Ive ridden 60 miles on the beer can with wheels and it rides just a touch stiffer than its steel brotheran the only changes I made was the BB insert I replace the bio-centric to the new two bolt Bio-cetric II the other one would slip a little. The other change was, I cut down the fork to fit without the miles of spacer above the stem. Man if we could get these bikes to the 26-27lb range then there would be no excuses for everyone not owning one!!!
    MR. 36er TROLL
    Nemophilist
    Hmmmm...
    Interesting that you can feel the added stiffness. To the good or bad? Firm or harsh? I wouldn't mind riding one, but from the cheap seats I'm pretty sure it would not for me.
    WIGGLER
    Feb 2007
    Quote Originally Posted by TrailMaker View Post
    Hmmmm...
    I dont know seeing a pic of you riding that perty snow bike, you look like you're 6footlerch this wheel size would be close to perfect for ya!!
    MR. 36er TROLL
    Nemophilist
    Hey;
    My impression is that they are more for flatland trail riding or adventure cruising. I'm no downhiller, but my assumption is that it might not hold up to harder riding, nor might they work well for tight east coast single track. This based on nothing other than riding a 29er, and guessing.
    Agreeing on the subtle curves, beautiful.
    Is this one also getting a Kawi green paint job ?
    Thanks for taking time to share !
    WIGGLER
    Feb 2007
    Cool-blue Rhythm Thanks
    Kawi green or a mountain dew induced shimmy chrome polish job!!
    MR. 36er TROLL
    Todd stopped by our shop this weekend while he was in town. This bike is a hoot to ride! Very cool project, and I'm glad the dropouts are working out well for him.
