Results 1 to 8 of 8
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Is the weld on this brake mount safe to ride?
    I just bought this used steel frame (On One Inbred) on the interwebs and everything looks good with the possible exception of the brake mount. It's definitely a hideous weld, but is it going to fail on me? I'm planning on powdercoating the frame after a friend welds on some ISCG tabs, so I could possibly have him clean it up.
    The other side for comparison:
    Nov 2008
    Welds are gorgeous. I weld for a living, and it appears his hand just moved. The puddle isn't contaminated. That's what causes cracks.
    Ride it hard
    Nov 2008
    Plus its a low stress area. In comparison to let's say, the bb or the lower headtube joint
    Sent from my HTC HD2 using Tapatalk 2
    Reputation: supersedona's Avatar
    Dec 2012
    I wouldn't worry about it at all. As said, quite decent
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    Nemophilist
    Reputation: TrailMaker's Avatar
    Yeh;
    T'aint purdy on the backside there, but it won't break. Solid and sanitary out on the outside. You could purty it up be beveling back that edge a bit before you refinish it.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Plays with tools
    Reputation: customfab's Avatar
    undercut is one of the worst welding defects, but there is plenty of metal on that brake mount to keep it put for many years to come. I certainly wouldn't have your friend try to re-weld the backside. Putting it through another heat cycle isn't going to do you any favors.
    Big Gulps, Alright!
    Thanks or the replies guys! I'll probably just leave it alone if it's not an issue. Just checking to make sure, because I have plans for this bike. My build thread is here: Second chance for an old frame: Custom Inbred build (Photo heavy)
    On a different note: does anyone foresee any issues with adding ISCG tabs? My buddy has been welding frames for a small BMX company for at least a year now. Anything I should make him aware of that he may not know?
    Adz
    Adz is offline
    Jan 2013
    Looks good imo
