Results 1 to 9 of 9
    True Temper Verus
    Thinking about a custom road frame. The high-end frame builder I am looking at generally works with True Temper OX platinum, but they also do house brand frames for a local bike shop using True Temper Verus. They are significantly less than the name-brand OX frames. Looks like Verus is a heavier, lower grade steel. But would it make that much of a difference for a Clydesdale weekend warrior like me?
    Framebuilder
    Reputation: Live Wire's Avatar
    Who knows what you consider a difference or how much a little weight matters, but both steels can make great bikes.
    FWIW, I'll bet the significant $ difference between the two frames include other factors beyond the materials cost. Verus vs OXPLAT is just $5-20 per tube more expensive.
    Read all about TrueTemper tubing here: Double Butted True Temper 4130 steel bicycle tubing
    Note that Versus tubes are also available with/without heat treating. Compared to OX tubing, the lower strength verses tubes will be thicker (so they are sufficiently strong) but this extra thickness also adds stiffness to the frame so might actually be a better fit for your intended use.
    Moderator Moderator
    Reputation: Walt's Avatar
    There is no issue
    The only advantage of the higher-end tubing is less weight - and we're talking maybe 200 grams for the whole frame. If you're a clyde, say rider+gear+bike of 250 pounds or so, then you're talking about 1/5 of 1% of the total mass. Big deal. There are a lot of fun things you can do for several hundred bucks that are probably more fun than having a bike that is a tiny bit lighter.
    -Walt
    Quote Originally Posted by loginhater View Post
    True enough....but from the customer's point of view, I would want at least one high end tube!
    Squelch the weasel.
    Reputation: JaquesN's Avatar
    This seems relevant: http://www.habcycles.com/m7.html.
    It's a copy of an article from 1996, printed in Bicycle Guide, where they had a set of otherwise-identical road bikes made with an array of tubing from cheap to expensive. Same geometry and components. The result was that the author could tell the difference, but not always, and didn't end up preferring the "best" one.
    Quote Originally Posted by Yogii View Post
    I'd rather a high end bike. Tubes are just stuff- sometimes the right tube for the job isn't the spendy and thin one.
    Eric Estlund
    www.WinterBicycles.com
    Eugene, Oregon
    Reputation: laffeaux's Avatar
    Quote Originally Posted by JaquesN View Post
    This seems relevant: Magnificent 7.
    Thanks for posting the article. Definitely an interesting read.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Take the True Temper Verus, I've had good luck...
  1. True Temper Bi-Ovals
    By shandcycles in forum Frame Building
    Last Post: 04-15-2010, 12:01 PM
  2. Some new stuff from True Temper
    By Walt in forum Frame Building
    Last Post: 06-05-2009, 10:34 AM
  3. Dedacciai Cro-Mo vs. True Temper OX ?
    By the_dude in forum Kona
    Last Post: 02-26-2009, 04:46 PM
  4. True Temper OX3
    By RockyWanderer in forum Vintage, Retro, Classic
    Last Post: 11-18-2005, 02:02 PM
  5. New True Temper legs?
    By donkey in forum 29er Bikes
    Last Post: 05-19-2005, 06:06 AM
