Results 1 to 6 of 6
    Reputation: metrotuned's Avatar
    New question here. Titanium Fork Steerer Tube Crack
    Was service bleeding the front brake when I noticed this crack in the steerer tube from underneath the fork. I'm relieved to have found it as I bombed down a high speed descent just the other day. Thoughts? Is the fork done? What happens when this weld fails? Repairable?
    Attached Thumbnails Attached Thumbnails Titanium Fork Steerer Tube Crack-titanium-fork-crack-steerer-tube.jpg
    Producer, Actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
    Reputation: Testmule's Avatar
    Jul 2013
    Quote Originally Posted by illnacord View Post
    Looks repairable to me with my limited titanium knowledge and experience, but there are much more knowledgable people on this forum that can give their opinions.
    As long as no catastrophic failure comes out of riding it to a Titan tig welder to spot weld. Speaking of which, I'm seeking a welder that works with titanium in the Bay Area, anywhere in the Bay, preferably within 10 miles of a BART station.
    Last edited by metrotuned; 01-20-2014 at 02:57 AM. Reason: Seeking experienced TITANIUM welder
    Harrumph
    Reputation: G-reg's Avatar
    I'm not really Ti, or even TIG, smart. But I'm guessing you won't find a credible Ti guy who will want to touch that.
    I'm guessing this is not a fork made buy a small builder. Meaning mass produced for cheap in China or thereabouts. If I'm wrong you should be figuring out who did build it and asking them these questions.
    Rule #1 with Ti is it needs to be VERY clean prior to welding, and VERY shielded with gas during welding. I don't know how either would be accomplished in this case.
    If the rest of the welds on a segmented Ti fork are potentially of the same quality I wouldn't ride it even the broken weld was fixable.
    Slowly slipping to retrogrouchyness
    G-reg, thanks for the couch opinion. Don't associate durability with who built it: if it's a factory with Ford assembly line, or an angry drunk in a garage, and for what cost has little to do with it. I've seen Black Sheep ti unicrown forks break, too. I'll do the legwork and report back.
    Update: Fork replaced under warranty
    Advised NOT to ride the fork. Replacement fork in hand. Manufacturer replaced under warranty. The replacement fork crown appears distinct to cracked fork crown.
  1. 1 1/8 Straight Steerer tube To 1.5 Tapered tube Fork Conversion
    By xOffxThexLipx in forum General Discussion
    Last Post: 03-06-2014, 09:25 PM
  2. Where to cut steerer tube on new fork...Guardian
    By getagrip in forum Airborne
    Last Post: 02-25-2013, 01:45 PM
  3. Cutting Steerer Tube on fork
    By p08757 in forum Beginner's Corner
    Last Post: 01-10-2013, 09:20 AM
  4. fork steerer tube measurement
    By Metanoia in forum Beginner's Corner
    Last Post: 09-27-2011, 10:56 PM
  5. fork steerer tube length problem
    By illegalsmile in forum Bike and Frame discussion
    Last Post: 07-12-2011, 07:14 PM
