Results 1 to 6 of 6
    Mar 2013
    Tap drill size calculator
    You probably have a chart/card for this but it's kind of a cool trick:
    Newman Tool's handy hint.For Metric sizes only. Diameter of thread minus the pitch equals the tap drill size.
    eg. M6 x 1
    6 - 1 = 5mm
    and you thought metric was difficult ;-)
    thanks to Jay Steinbuchel of Barksdale Control Products for the following:
    This works for all 75% threads, not just metric.
    For example, the tap drill for 3/8-16 is 5/16.
    The pitch is 1/16". (1 / threads per inch = inches per thread)
    3/8 - 1/16 = 5/16.
    For other sizes that don't work out so nicely, just use the closest drill size.
    This came from here(calculator at bottom of page):
    Tap Drill Sizes
    RCP Fabrication
    Thats pretty slick
    Plays with tools
    Reputation: customfab's Avatar
    Now if only I had a metric drill index.
    650b me
    Reputation: golden boy's Avatar
    Today's rainy day project was to figure out fasteners and corresponding tap for attaching badges to head tubes. I went with 18-8 stainless button head socket cap screw, 4-40 thread, 1/4" length. Does that sound about right? Drill size is #43...guess that's a special order bit, eh?
    Randomhead
    There is a place here in town that stocks number drills, you might have the same. This isn't a particularly big town. 43 seems like a weird size, but since it's the standard drill for 4-40 most industrial places probably stock it.
    I worked with someone that had a formula memorized for SAE tapped holes. I didn't use it enough to remember, so I just google for tap drill chart.
  1. Want to drill my RD's
    By Floyd298 in forum Fat bikes
    Last Post: 10-21-2013, 03:27 AM
  2. Let's do the drill!
    By titaniumgearsolid in forum Tooltime
    Last Post: 06-04-2013, 10:28 PM
  3. Stuck Chainring bolt...to drill or not to drill?
    By bsgerig in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 05:55 PM
  4. Drill valve hole
    By BARAvnzla in forum Wheels and Tires
    Last Post: 08-04-2011, 10:40 AM
  5. Can I drill my Kings to 9mm for RWS skewers
    By jeremy524 in forum Wheels and Tires
    Last Post: 02-15-2011, 04:35 PM
