    Reputation: bluechair84's Avatar
    IS tab specs / diagram
    Hello all, Long time since I started my 180mm carbon thread - progression on the project is going very slow. I'm going to pop an update in that to explain what I'm up to. But my main question is; does anyone have to hand a file or link showing the locations of the holes in an IS rear disc tab? All I can find from google is that the tab holes need to be 51mm apart, but nothing on their distance from the axle or there angle. A couple of other links I found on various websites were dead, or for post mount.
    Moderator Moderator
    Reputation: Walt's Avatar
    Couple links:
    If you have the capability I'd just do postmount, though.
    Cheers, I might have to email anvil. I could trace to paper my existing IS tabs but... it just seems a bit imprecise! I'm sure it would be fine... And as for post, I'm currently experimenting with composites and I think the heatsoak from the caliper into the post mounts would be damaging. I'm planning on using an IS:PM adaptor to work as a heatsink/deflector :s Cheers Walt
    Thanks for the links Walt - just to let you know, I didn't get an email to say new posts had been made as you'd edited your post. I came back here to put up my own measurements (40mm and 78mm radius from the axle, 51mm apart). Might be worth just adding a new reply so subscribers are notified.
    Thanks again
  1. Sun Ringle Black Flag Pro parts diagram
    By therollex in forum Wheels and Tires
    Last Post: 08-03-2013, 12:29 AM
  2. Exploded diagram of lower pivot on RIP 9?
    By AZmtncycler in forum Niner Bikes
    Last Post: 07-15-2013, 02:46 PM
  3. Mj 259e driver diagram?
    By 4&20-9er in forum Lights DIY - Do It Yourself
    Last Post: 09-10-2012, 11:16 PM
  4. Diagram on axles moving in drop out under braking
    By Slash5 in forum Singlespeed
    Last Post: 05-08-2012, 05:05 PM
  5. Mukluk Rear Hub Diagram.
    By singlespeedstu in forum Fat bikes
    Last Post: 01-19-2011, 05:44 PM
