    Mar 2012
    Is T-300 stronger than T-1000?
    Hey guys,
    I was looking at Toray's website and I noticed that T-300 carbon fiber is rated at a much higher (1860 Mpa vs 1570) flexural strength than T-1000 fiber for a 60% fiber volume matrix, even though T-1000 carbon fibers are obviously much stronger than T-300 in pure tensile strength (6370 Mpa vs 3530)
    http://www.toraycfa.com/pdfs/T1000GDataSheet.pdf
    http://www.toraycfa.com/pdfs/T300DataSheet.pdf
    Does anyone know why this is? Does this have to do with T-1000 fibers being thinner and more likely to experience micro-buckling or something? Would T-1000 be stronger than T-300 if it was compared in a 70% fiber matrix like what most bike frames are made of?
    Btw, I think HexCel actually makes the strongest carbon fiber according to their website, both in composite form (flexural strength) and in pure tension.
    http://www.hexcel.com/Resources/Data...heets/AS4C.pdf
    http://www.hexcel.com/Resources/Data...heets/IM10.pdf
    In real-world applications, I think flexural strength, or a combination of tensile and compressive strength, would be more important than pure tensile strength.
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    I cannot really speak to much of what you are asking, except the last part, perhaps. I do not think you will find a single tube in a bike frame that sees anything but a complex, multi-directional load. It would seem to me that the tubes would need to reflect that in their design to a large extent. At the same time, there is obviously a lot of potential to tune the ride by selecting weaves of a particular nature for a certain position in the frame. In fact, it might be far more complicated - but beneficial - to do that with carbon than with any other material.
    For now, steel is plenty complicated for me.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    will rant for food
    Mar 2012
    That doesn't talk about how carbon fiber behaves under compression.
