Results 1 to 5 of 5
    Aug 2013
    suspension forks on a non sus bike
    hey guys,
    im after some help with my bike, ive had it wile and i was wondering it is possible to put sus forks on it.
    all help is greatfull.
    here is my bike specs:
    dawes xc 1.0
    Frame:
    Fork:
    Dawes 6061 alloy with MTB geometry
    Rigid steel unicrown
    Headset: Threaded 1.1/8"
    need any more info please ask ill try help you out
    thanks in advance
    Dec 2012
    It is possible, but I wouldn't recommend it. It looks like your bike has a non-suspension corrected fork on it. I can't find the geometry from your bike, but the 2013 model has a 70 degree head angle. Putting a suspension fork on it will raise the front end a significant amount and leave you with a very slack head angle and a bad handling bike.
    Aug 2013
    thanks for the reply, ive been looking at the same make bikes but newer than mine, they have the same frame but have sus. i get what your saying about bad handling, but if i was to do it what else would i need?
    new headset and stem?
    Dec 2012
    The frames with suspension may appear the same, but they were probably designed for the longer axle to crown measurement of the suspension fork. If you go ahead with replacing your fork you should only need a threadless headset(probably a standard 1 1/8" 34mm external cup will fit your frame), a stem with a clamp size to match your current handlebar and probably a few 5mm spacers to give you room to adjust your stem height.
    Aug 2013
    really appreciate your help. thanks very much
  1. New suspension forks
    By conorr_a in forum Shocks and Suspension
    Last Post: 05-26-2013, 06:52 PM
  2. Chinese mountain bike suspension forks stripping
    By duggs in forum Shocks and Suspension
    Last Post: 03-26-2013, 02:40 PM
  3. Suspension forks question
    By MrAitchGee in forum General Discussion
    Last Post: 10-11-2012, 02:21 PM
  4. Replacement Suspension Forks
    By CS2 in forum Vintage, Retro, Classic
    Last Post: 06-29-2011, 07:23 PM
  5. Suspension Forks on a BB Disc
    By wehey in forum Cannondale
    Last Post: 04-14-2011, 11:55 PM
