Results 1 to 5 of 5
    Cleavage Of The Tetons
    Speaking of paint....
    Anyone blast/repaint Fox Forx crowns/lowers? any tips, things not to do, etc? powdercoat a good/bad idea?
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    As far as paint goes its about prepping a good surface for proper adhesion. Remove the decals. Sand with 400 until the orange peel of the previous topcoat is flattened. wipe with a tack cloth,tape off and prime with a light coat of two part primer/sealer meant not to be sanded. Within the recoat window apply color coat in two light coats for full coverage. You can add a little hardener for added durability. Topcoat with two coats of urethane two part clear. Take the tape off after 1 hour. Wet sand as needed with 2000 after 16 hours. Buff it with wool bonnet and compound and final polish compound with foam pad. Add new decals
    Done.
    Jan 2011
    Powder is a bad idea because the lowers will warp from the heat.
    As requested by the MTBR gods, I am the voice of Groovy Cycleworks, check it out... http://www.groovycycleworks.com
    650b me
    Reputation: golden boy's Avatar
    That's awesome, Rody! Don't know if I'll ever attempt it, but it's good to know it can be done. Also, nice to know you don't have to take the whole fork apart.
