S-Bend Steel Down Tube: Good Idea Or No?
Hi Guys,
I'm looking at getting a steel 29er frame built and was going to request an S-Bend type curve at the headtube end of the down tube for fork clearance but I have been told that it will create a weak point. I know the new Niner Sir 9 has a bend there but I guess they have a specially butted down tube? I would be using a plain gauge cro-mo down tube. So am I just asking for trouble?
Consult with your framebuilder and trust their advice if you are trusting them to build your frame. Why cheap out for plain-gauge tubing on a custom built bike? Plain gauge that is thick enough to be bent and welded on the ends will be unnecessarily heavy for the middle. Pre-bent down tubes are available from Nova;
NOVA CRMO 38mm DOWNTUBE FOR MTB/29er WITH BEND :: 38.1mm DOWN TUBES :: ROUND TUBES :: MAIN TUBES :: TUBES STEEL :: Nova Cycles Supply Inc.
Thanks for the advice and the link GrayJay.
The one used by Niner (or very similar) are also available direct from Reynolds...
By trhoppe in forum Drivetrain - shifters, derailleurs, cranks
Last Post: 09-06-2015, 08:52 AM
By bnelson in forum Salsa
Last Post: 12-23-2012, 06:26 AM
By roman in forum Niner Bikes
Last Post: 05-03-2012, 01:57 AM
By lawfarm in forum Cyclocross
Last Post: 02-05-2012, 01:36 PM
By deuxdiesel in forum Fat bikes
Last Post: 02-02-2012, 04:49 PM
- You may not post replies
- You may not edit your posts
Forum Rules
