Results 1 to 7 of 7
    Ripped out Bottle Braze-On
    So I've had a BionX battery attached here for 11 months and about 2000 mi. As I was removing the system because it's garbage I noticed that after cutting the extra zip ties to help support it it just fell off. This is on a Surly Big Dummy on the tube between the seat tube and seatstays.
    Any suggestions on what I should do about this? Can I grind it smooth and round to prevent any cracks then just JB Weld a plate over it and call it good?
    Reputation: supersedona's Avatar
    Dec 2012
    I would vote epoxy and plate as the most readily doable solution. Do you have the original piece? If so, you may be able to back the epoxy and remount it in.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    You could "epoxy" (or some other metal bonding adhesive made for that purpose) a plate over that. Might help strengthen it, and keep it from cracking. Might. You might even put a nutsert in that plate and restore the bottle mounting. You might even go the extra mile and have that plate TIG welded in place.
    The forgiving nature of steel...
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by TrailMaker View Post
    Welding it is an option, I'm just curious if it's worth it. I don't care about the bottle braze-on. This tube just helps stiffen the rear end a bit more. I'm just trying to decide if it's worth it to give a **** to do that or not.
    Who turned out the lights
    Reputation: Francis Buxton's Avatar
    I was thinking make a "round" plate out of some oversize cromo and just silver or bronze braze it on there like guys do with sleeves. The way that is now, I would think you could get stress risers out of the jagged corners. By putting on a rounded plate, you should be able to alleviate that.
    Dejavu
    I fixed a similar problem earlier this year on an old Giant mountain bike. In fact it looked almost exactly like the picture you posted.
    I cleaned up the ragged hole and made it oval making sure there were no spider cracks left. I then machined a plug that fit the new clean oval hole. I fashioned this plug to also have a thicker step in the center that I drilled and tapped for the bottle mounting. Then I TIG welded it in place, sanded and painted.
    Use a small tungsten and be careful with the heat as the tube is probably quite thin in the middle. I made my patch a tad thicker than the surrounding tube and directed the heat towards it and it made welding reasonably easy.
    Good luck.
    Turned out quite well.
  1. Looking for someone to braze disc tabs on an old schwinn around kzoo
    By ct_racer in forum Midwest - IL, IN, OH, KY, IA, MO, MI
    Last Post: 09-14-2012, 01:46 PM
  2. Wholesaler or Supplier for Braze-ons?
    By western high plains in forum Frame Building
    Last Post: 02-05-2012, 09:36 AM
  3. Braze-ons
    By mattty in forum Frame Building
    Last Post: 10-13-2011, 11:51 AM
  4. Front Der Braze-on Location for a Road Frame
    By CurbDestroyer in forum Frame Building
    Last Post: 03-11-2011, 08:49 PM
  5. Braze on , on an anthem
    By FierceRider in forum Weight Weenies
    Last Post: 02-12-2011, 05:47 AM
