Results 1 to 6 of 6
    Nov 2013
    Removable dropouts
    I am making a 93 cadex alm-1 into a single speed. The alm-1 has bolt on vertical drop outs. I am looking to swap these out for track/BMX style. I am unable to find anything like this online.
    Does anyone know where I can get track/bmx rear dropout that will bolt on to this frame?
    pic:
    https://imagizer.imageshack.us/v2/60...0/198/tuoe.jpg
    Since this is the framebuilding forum, the most obvious answer would be to make them! Looks like they are made from flat plate. Even if you find someone to do it, it shouldn't be too expensive. Could even waterjet cut them.
    I've never seen them aftermarket as you were hoping.
    Moderator Moderator
    Reputation: Walt's Avatar
    Just use an hanger-mounted tensioner. Or make yourself some track ends (doable with hand tools). You will definitely not find a compatible part aftermarket for a 20 year old bike.
    -Walt
    For slightly less amount of fabrication, you might also be able to start with some ready-made horizontal track dropouts, cut and drill them to fit onto the cadex frame.
    DROPOUTS :: Nova Cycles Supply Inc.
    ali'i hua
    Reputation: SlowSSer's Avatar
    is Kavik still making them?
    Quote Originally Posted by SlowSSer View Post
    Yes, we are...
    Well.....frame number 5
    30 026 | Flickr - Photo Sharing!
  1. Stickers/Decals removable?
    By spikebike in forum Santa Cruz
    Last Post: 07-18-2013, 03:23 PM
  2. Using Stans With Non Removable Cores
    By drofluf in forum Fat bikes
    Last Post: 05-17-2013, 11:42 AM
  3. XX1 - Spider removable?
    By thorkild in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-19-2012, 02:23 PM
  4. Sid graphics removable?
    By morrisond in forum 29er Components
    Last Post: 04-21-2012, 10:10 PM
  5. RS- removable bosses?
    By BuffaloSprocket in forum Shocks and Suspension
    Last Post: 11-30-2011, 10:48 AM
