Results 1 to 7 of 7
    Reputation: arcdesigns's Avatar
    Re-painting a frame where the decals are under the clear coat?
    Hi All,
    Looking for advice on the best way to restore a frame that has the decals and makers badge under the clear coat?
    I was thinking of spraying a one stage with the decals masked off and then a clear over everything.
    Thanks in advance.
    Dec 2012
    Good luck with masking those decals. If you're really good with tape and a razor knife, you can spray it with a urethane base and clear over it. A much easier option is to have the decals replicated.
    Quote Originally Posted by DSaul View Post
    Where and how can I have the decals replicated?
    Reputation: swift's Avatar
    Try local print shops.
    You are likely to be able to find the font online, somewhere. ...Or even cut from your photo above. Work it to your own liking, then save the file and take to your local print shop.
    Dec 2012
    This guy has been recommended on other forums. I have never used him myself, so I have no experience with his work.
    mylar and vinyl
    Reputation: davesauvageau's Avatar
    Sign builders usually do die-cut or printed vinyl as well but it will not be exactly the same. The logo on the frame looks like it is a 2-color job, which will require either two layers of vinyl or printing on the vinyl. The graphics under the clear are probably printed water-slide decals that are very thin and can be painted over easily. Why do you want to re-paint it? If I was doing a new paintjob I would make it unique, something different. I personally get all of my bikes powdercoated, I don't mess around with painting them myself. I love the finish and durability of powdercoat as well as the quick turn-around at a decent shop.
    The recommendation from previous posts does make water-slide decals which would be your best option. Paint the frame, apply decals and finish with clear-coat.
    water mount
    My motorcycle runs on infant blood
    Mar 2013
    mylar and vinyl
    Their website says wholesale only, they do not sell on a retail basis.
    Brian
  1. Clear coat over decals into a fresh Powder Coated frame.
    By Pepelepu in forum General Discussion
    Last Post: 01-23-2016, 12:23 PM
  2. Re-painting a frame where the decals are under the clear coat?
    By arcdesigns in forum Vintage, Retro, Classic
    Last Post: 07-13-2013, 01:05 PM
  3. Clear coat options on steel frame?
    By MiggySawdust in forum Frame Building
    Last Post: 06-03-2013, 10:42 PM
  4. Paint or clear coat an SC carbon frame?
    By BTTR in forum Santa Cruz
    Last Post: 06-15-2012, 09:24 AM
  5. Spray painting to hide decals on frame
    By roc865 in forum Bike and Frame discussion
    Last Post: 06-21-2011, 09:31 PM
