Results 1 to 2 of 2
    Jan 2013
    Questions about rohloff dropouts on a Moonlander
    I have to have a Moonlander frame repowder coated and was wondering about the change of the rear drop outs to the Rohloff dropouts.
    Would that change affect the use of the stock Surly wheel and casset?
    I might change over to a Rohloff igh if the current setup does not work out and feel the time to change the frame geometry would be now if the Rohloff dropouts will work with the Surly wheel and derailers...
    I LOVE ORANGE keep them coming, if I wanted to change I would have done it 50-60 years ago....
    Harrumph
    Reputation: G-reg's Avatar
    You can use an appropriate Rohloff hub / accessories with the stock Surly dropouts.
    Now if you are talking about having new drops brazed in that's a bit of a different story depending on the dropouts. Adjustable drops from Paragon have various inserts for just about anything, if you've something else going there's no short answer without knowing what drops are going to be used.
    Slowly slipping to retrogrouchyness
