Results 1 to 45 of 45
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    The PVD WarBird - The show bike that you won't see at the show.
    I going to NAHBS but I will be too busy with other projects while there to babysit a bike. I did this bike up as my virtual booth. Here it is, The PVD WarBird. A singlespeed designed to attack and kill. A weapon. The mix between a dagger and a tank.
    http://www.pvdwiki.com/index.php?title=PVD_WarBird_SS
    Gabe.....
    Reputation: Smokebikes's Avatar
    Bring it...............................................p lease
    "Roll your own..........." http://smokebikes.com/
    Who turned out the lights
    Reputation: Francis Buxton's Avatar
    Looks good Peter. Care to share any better pics of the driveside chainstay/bb connection/interface? I think I know what you did there to solve the chainring/tire issue, but I'm just curious to see a little more.
    Reputation: Evil4bc's Avatar
    Great build Pete , loving that color !
    Follow me on Instagram for up to date build pics -Brad4130
    Nem-Pro store
    Nem-Pro Blog
    Randomhead
    Quote Originally Posted by Smokebikes
    no piggybacking at the show...
    Gabe.....
    Quote Originally Posted by unterhausen
    Not to be upidstay.....but what is "piggybacking"?
    I know that bike is sweet and all but wouldn't it be fun to take that thing into the forest for a real ride?
    mbtr member
    Reputation: scottzg's Avatar
    Things i like:
    color
    name
    geometry
    saint parts on rigid bike
    saint brake and 140mm rotor
    bb/chainstay design
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Relax. I'm a pro.
    PVD consistently shows off some of the coolest sh!t here. I dig it.
    PS: Glad it's a 26er rather than a 29er.
    Another nice one, Pete. I had no idea you did the R3 trucks (was browsing your wiki). I used to snowboard with John Gilmore.
    Too many bikes, not enough time.
    Reputation: zipzit's Avatar
    Aug 2005
    Peter,
    Very nicely done. I really like how the rendering matches the real thing. Its almost difficult to tell what's real and what's virtual. Nice bike.
    FYI...no forests in Richmond However, I'd be up for a ride regardless!
    Yup, thats nice allright, the chainstay offset hoopty is super clean too.
    Naive question: Why build a frame with suspension corrected geometry then fit rigid forks? I'd have thought it would be better to design the frame and forks around a non-corrected design.
    Quote Originally Posted by Francis Buxton
    Agreed. Flat plate offsetting a sliced tube...?
    pvd
    pvd is offline
    Quote Originally Posted by nicknoxx
    It would be, but this bike will be used with a suspension fork about 95% of the time. I say that in the wiki. I just wanted to have a completely integrated front end and show off a bit of design in the fork. Now that the bike is getting dirty the real fork goes on it.
    pvd
    pvd is offline
    Sure. I'll dig that up. It's pretty slick. The print and model actually show a different design than was used on the bike. I continue to evolve my CS/Tire/Chainring solution. It's a hell of a problem, Especially to get big tires in on super short stays and keep all three rings.
    well i'll take guess here,peter can correct me if i get anything wrong. He wants the handle bar exactly where it is,if you shorten the fork and extend the steerer tube of the frame and the steerer of the fork(downward) that's lengthening two tubes,one rather thick and the frame tube kind of big,more weight and sort of a funny aesthetic. Now if you shorten the fork and leave the steering tubes the same length,you get a very odd stem, a lot of rise ,very short.. I think the last bike of his i saw was kind of along those lines One last possibility i thought of while writing is to have riser bars or those old style welded up bar ste combo. Pvd went with this particular balence, infinite variations are possible, this is sort of a mid ground, i wonder if there's a particular suspension fork he's got in mind. This design lets you have the possibility of a quick easy 5 bolt change over. My .02
    pvd
    pvd is offline
    I've been moving toward longer head tubes lately. I'm trying to get more bearing separation to reduce the loads that the bearings are working against and to give more front end feel and precision to the bike. The Millenium Falcon (http://pvdwiki.com/index.php?title=P...lennium_Falcon) started toward this, but that was a pure race bike for a young gun, so it didn't really stand out. On this bike, I was limited in that I had a perfectly good suspension fork with a 200mm steerer that I was hoping to use so I didn't have to buy a new one. That forced me to raise the stem slightly. Plus, I'm not looking to make the head tube crazy long. Just a little extra for added strength. I'm really loving the astetic short low stems and long front centers. It just makes the bike look so serious.
    What I love about framebuilding as a hobby is that I get to really think deep about what I'm trying to do, build and example, then ride it to see if that was the case. It's very fulfilling to continue to squeeze just a little more out of something that has been studied for about 150 years. It just shows how much we can still learn about anything.
    awesome
    Reputation: dblspeed's Avatar
    Very nice.
    I'm wondering about the crankset choice, is that for showing off a bit or is it because the Saint superior stiffness offers an advantage in ss over a lighter, no nonsense alternative like the SLX?
    pvd
    pvd is offline
    The Saint cranks were done for fun and bling. I usually modify SLX or XT cranks for SS use. I wanted to have some fun with this build though. I've been running the Saint brakes on all my trail bikes lately. They are absolutely amazing. The best there is. The just ain't light.
    Quote Originally Posted by pvd
    Right on Pete, that's what so many folks forget to embrace
    As requested by the MTBR gods, I am the voice of Groovy Cycleworks, check it out... http://www.groovycycleworks.com
    dru
    dru is offline
    They only thing I don't like about that bike (and others you've done similarly) is the blacked out seat tube extension. Just leave it the frame colour. Otherwise beautiful stuff like usual.
    Drew
    occasional cyclist
    Reputation: dRjOn's Avatar
    its inner tube to stop crap going in the seat tube slot i think....like old bontys used to have.
    interesting numbers. very new school...if thats the word. short back end, slack angles, 80 ish trail, lowish bb...im sure it'll rail....nice. so how much sag does a rigid length of 447 equate to? about 25mm or so?
    dru
    dru is offline
    Indeed it is an inner tube; aren't I a dummy.....
    That is a really good idea I may have to try....
    Drew
    occasional cyclist
    here's a question,when you lengthen the headtube are you really strengthening the frame by much/any, geometricly you're moving away from an actual front triangle towards more of a trapazoid(?). Your leverage on the welds and other materials improves.
    Reputation: Roadsters's Avatar
    I'd like to know what this bike weighs.
    Reputation: NorseRider's Avatar
    I really like it, Peter. Nice work.
    only thing i would advise from experience of the old bontys is if you do use innertube, periodically lift and dry it out underneath. new steal is way less corrosion prone, but its worth an ounce of prevention.
    longer headtubes reduce the effects of fork leverage on the frame, which i think can mean you can either use lighter tubing or have a stronger frame...i think! wider spaced 2 point connection of a lever.
    the more sloping a top tube the more twist flex i believe is possible...not many loaded tourers have sloping top tubes which i think has something to do with this....
    i believe the angle the tubes join the other tubes at has quite an effect also....dunno. will a rider notice? if they are sensitive or push the envelope of the bike id say so. if you ride well within the design parameters of the bike, prolly not.
    i spose it raises the question as to whether with a custom frame you'd be better to have a longer headtube (as long as standover will allow) and use a negative rise stem to get back to the correct bar height. aesthetics aside ... who knows....
    amazing how much a coffee on sunday morning leads to waffling... :-)~
    What's up with the .2 on the seat angle? On purpose, or arrived at from other paramters dictating it? Curious if your splitting angles that fine on purpose.
    -Schmitty-
    pvd
    pvd is offline
    Hey folks,
    I added some more detailed pictures to answer some questions. Take a look at the wiki for another 12 pics.
    http://pvdwiki.com/index.php?title=P...rd_SS#Pictures
    pvd
    pvd is offline
    Quote Originally Posted by Schmitty
    I use saddle position when designing a frame. By making sure to use really good numbers for your saddle and rail geometry and setpost geometry you can split seat tube angles to get exactly the position you want. I was trying a slightly new handling fit on this bike to put just a little more weight on the front tire. That rocked me forward about the bb.
    Sure, that 0.2 degrees only equates to 2mm of setback change, but I figure it's worth getting position exactly where I want it so that I can be centered on the saddle rails. And really, since I'm using a digital protactor to set my jig it really makes no difference weather I'm setting to 70.5 or 70.7 since the tool reads to 0.1 degree of resolution.
    Quote Originally Posted by dRjOn
    This is only because "touring bikes" tend to be more traditional both in construction and components. Plenty of non-traditional touring bikes have sloping tubes, and are not more flexible. This ignores the fact that some/certain flex in a touring bike could be desirable. A compact frame is likely to be more laterally stiff than a traditional frame (with a few simple assumptions you could do the math out on the moments). Check out Salsa Fargos, Tout Terrain, etc.
    Pete, did you sleeve the drive side CS, or just butt-weld it? I thought you had mentioned awhile ago that you did some sample butt-welded CS and did some destructive testing on them.
    pvd
    pvd is offline
    Quote Originally Posted by Linnaeus
    Those are butt welded. I had to give it a try. One thing I did is make sure to have a very robust extremely smooth fillet weld on the inside of the angle. Afterward I added a little silver in that area for a little extra support and smoothness.
    I had prototyped this type of joint about a year and a half ago, but it never went onto a bike. Destructive testing showed that the joint is good, but that's a little different than cycles and load in place. This is my first bike with that design.
    Gabe.....
    Very clean buttwelds...........did you build your own jig to hold it? Who painted it?
    Reputation: ted wojcik's Avatar
    Mar 2006
    Very nice bike. Many innovations. Stop by my booth at NAHBS if you get a chance. I'd like to chat if you have time.
    pvd
    pvd is offline
    One issue with the whole 'longer head tube' thing is brake lever clearance over the top tube. If there isn't any room, the levers will bang the top tube. That is bad. This bike is just able to clear the top tube with well placed levers. If the head tube had been any longer, that would not have been possible. I just wanted to point that out.
    Two honest mountain bike rides on the bikes so far. Nothing too obscene, just average Marin singletrack. The bike works amazingly well. Much better than I had hoped even given the muddy conditions. It's hard to get used to the 100mm fork when I'm used to 140mm. Definatly different in the rough. Anyway, it's a great ride. The faster you go the more stable it gets. Up and down traction and balance are awesome.
    Reputation: MMcG's Avatar
    Jul 2003
    Thanks for the extra pics - that chainstay area is pretty friggin cool.
    Nice....... I want one!
    Reputation: defconfour's Avatar
    Sep 2004
    Wow! I was out of town last week and finally got a chance to really check this build out. There are so many slick pieces on it. Everything functional but looks great too.
    First off, great documentation. Photos and complete write up are top notch.
    Love the pressed in BB. I've have a spanish BB on my DJ bike and it's been great. Did the wider BB shell help in getting a bit more room for the tire? Beautiful job on the driveside chainstay. I think the crank arm flush to the shell looks so clean. What size bearings did you use?
    Steel stem with the removable 4 bolt face plate looks sweet - the thinner steel plate slims the 31.8 bar a bit.
    The knurled brass tightener and the 12 point bolts for the sliding drops are nice touches.
    140 rear rotor is small and keeps the rear end clean especially with a SS. I'm guessing the braking isn't that far off of a 160 setup.
    The steel fork is beautiful and I think that small crossbar fills in the space nicely. Keeps it from looking too "suspension corrected". And matching that up with the integrated headset and the downtube gusset is treats.
    I agree with the taller headtube and longer front end/shorter stem. It does give the bike a serious look with the sloping lines. It's also functional and I prefer the ride. I don't know how the hell I used to ride with 135mm Salsa stems back in the old days.
    I agree, I think that is one of the better looking custom stems I've seen. You did a great job on it - very clean.
    pvd
    pvd is offline
    Thanks guys. I try to step it up on every build. This one needed that little bit extra since the show was coming up and everyone is all excited.
    See you next week in Richmond!
    Well done! Do you find the "more forward" position affect pedaling? Did you move your knee forward relative to pedal? Enjoy Dixie.........just don't fall in love with Stock Cars.
    Reputation: Jon Edwards's Avatar
    Liking!
    Why the bash ring *and* the taco...? I can understand either/or, and I can just about understand both on a DH bike with a low BB on a really chundery course, but not on a trail/xc bike.
