Results 1 to 3 of 3
    Newb Tube Miter Question. Double miter?
    I'm building my first frame so this is totally a NEWB question: If you have your seat tube and down tube slightly intersecting at the bottom bracket which tube do you double miter or do you double miter both?
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    The seat tube goes on first, and welded all around. Then the down tube goes on after. You mitre the down tube into the BB shell and seat tube.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Reputation: Evil4bc's Avatar
    Double miter the DT
    As Eric pointed out the first operation for "most builder's" is to weld the seat tube to the BB . I've moved away from welded the ST / BB together 100% as a first operation and now just take weld the ST / BB first then finish the mitering process for the rest of the frame including the DT chain stays and weld everything in sequence in the end.
    Follow me on Instagram for up to date build pics -Brad4130
    Nem-Pro store
    Nem-Pro Blog
  1. Down Tube, Head Tube miter on a mill
    By febikes in forum Frame Building
    Last Post: 10-14-2013, 04:34 PM
  2. Using Anvil main tube miter fixture for dropout miter?
    By Blitz Cycle Works in forum Frame Building
    Last Post: 04-18-2013, 12:52 PM
  3. The expensive way to miter tubes.
    By customfab in forum Frame Building
    Last Post: 02-05-2013, 09:43 PM
  4. Replies: 7
    Last Post: 02-01-2011, 11:01 PM
  5. Nova TubeNotcher basic miter template question
    By illcomm33 in forum Frame Building
    Last Post: 01-20-2011, 11:09 PM
