Results 1 to 3 of 3
    New frame headtube question/problem looks like headtube was welded on crooked
    I just bought a new frame and when inspecting it after shipping, the headtube looks like it was welded on crooked. It is a tapered headtube and the top of it is centered on the top tube but the bottom is offset to one side maybe 1/4 to half an inch. Is this normal? Any feedback would be appreciated. It doesn't look like it is bent and I'm sure I could mount my headset and fork. Would this affect handling? Do I need to return it?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by au97jeep View Post
    It would not be normal. Do you have pics?
    The cat's name is jake
    Reputation: BungedUP's Avatar
    Aug 2003
    While certainly not cool, it is possible that the down tube was mitered off center, and thus it appears that the headtube is crooked, when in fact it is straight with respect to important alignment planes. The downtube itself doesn't really matter alignment wise - it could be bent and off center, and the frame itself could still be straight (headtube parallel and in line with seat tube, which is parallel and in line with rear wheel, which is all perpendicular to axis of cranks). Bad form, but not necessarily indicative of a misaligned frame.
  1. Replies: 3
    Last Post: 08-17-2013, 02:37 PM
  2. Would you buy this alu headtube-dented frame?
    By Horacek in forum All Mountain
    Last Post: 12-12-2012, 01:11 PM
  3. Question about tapered headtube
    By grizzlyplumber in forum 29er Bikes
    Last Post: 12-06-2011, 11:17 AM
  4. Headtube reducer question
    By rswitz in forum Downhill - Freeride
    Last Post: 03-19-2011, 07:45 PM
  5. Need help with Blur LTc tapered headtube problem!
    By Nasi0ne in forum Santa Cruz
    Last Post: 03-01-2011, 11:11 AM
