Results 1 to 20 of 20
Thread: mystery tubes
    Squelch the weasel.
    Reputation: JaquesN's Avatar
    mystery tubes
    I received these in a bunch of tubes I bought as a lot.
    <a href="http://www.flickr.com/photos/jimn/10425529434/" title="MYSTERY TUBES by jimn, on Flickr"><img src="http://farm8.staticflickr.com/7355/10425529434_f62916f66a.jpg" width="500" height="299" alt="MYSTERY TUBES"></a>
    Each is marked "3593" and is about 280 mm long with a slight taper. Too short to even be a fork blade or chainstay for a 20" wheel. They seem to be about .8mm thick.
    Does anyone know what they are?
    Moderator Moderator
    Reputation: Walt's Avatar
    My *guess* is that those are unbent unicrown blades.
    The 4-digit number makes it look like they probably were purchased from Kirk at Bikelugs? You might ask him.
    -Walt
    Squelch the weasel.
    Walt, they are only 11 inches long - too short for a unicrown on anything bigger than a 16" wheel.
    I had the same thought about the numbers, since my tubes from Pacenti tend to come with these mysterious numbers on them, but I didn't find that number on his site. He changes inventory a lot.
    Jim
    Most Delicious
    Reputation: dr.welby's Avatar
    What are the ODs?
    Reputation: bobbotron's Avatar
    Nov 2007
    Clearly you need to turn them into a stool, super beefy rack, chain/seat bridges or some weird part of a truss fork. :P
    RCP Fabrication
    They are definatly from Kirk, give them a call I bet they will know what the old part numbers are.
    Moderator Moderator
    Yeah, ok, not many US-made 16" unicrown forks out there. Fork blades for a 'bent? Even those are usually 20", right?
    This is a great mystery! Better yet, what are you going to use them for? It should be at least as weird as the parts themselves!
    -Walt
    Dec 2012
    Fork blades or stays for a BikeFriday?
    Nov 2007
    Maybe they're part of a moulton bike frame kit?
    Most Delicious
    Quote Originally Posted by briderdt View Post
    Seems like a good guess:
    <img src="http://farm4.staticflickr.com/3311/3636102506_bf53d4e5b8_d.jpg" />
    Squelch the weasel.
    Quote Originally Posted by dr.welby View Post
    What are the ODs?
    They measure about 19mm (~3/4 inch) at the big end, and 12.5 (~1/2 inch) at the small. The wall thickness is about .9 at the big end and 1.1 at the small. They are 280mm long, or ~11 inches.
    There's barely enough material to make a fork for a 20" wheel. Maybe possible if you have some really long dropouts that extend the blades a bit, but I'm dubious about that one.
    Not that I have a better idea!
    Reputation: Feldybikes's Avatar
    I'll riff on what others are saying and guess fork blades for a Bike Friday Tikit (16")
    Reputation: jay_ntwr's Avatar
    If you don't find a use for them, I may just have an application for them.
    Squelch the weasel.
    Quote Originally Posted by jay_ntwr View Post
    Jay, PM me and I'll let you know. I don't see myself using them any time soon and would just as soon make room in the shop.
    Still waiting on a reply from Kirk. He said he'd get back to me this week but I'm sure he has more pressing items on his agenda than answering trivial questions from amateurs.
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    BikeLugs.com
    Found it.
    The awkward description sounded familiar. I've gotten quite a few bmx tubes from Kirk recently as he was closing out all TT stuff. I think I bought some of these just to have...
    Harrumph
    Reputation: G-reg's Avatar
    Wheeee! mystery tubes from Kirk! I impulse bought some stuff recently, and threw some cheap HT stock in the order. I just got it to day and looked at the order closer. I've now 3ft of really thick TT S3 Head Tube, beautiful steel.....But the 10.00 the tubing cost won't cover a 10th of the cutters it will go through in using the stuff.
    Slowly slipping to retrogrouchyness
    Squelch the weasel.
    Awesome work Jeremy!
    But... these are too short to be seat stays, even for a 20" wheel. Mystery sort-of solved!
    I'm using them as a seat tube bridge support for low top tube mtb frames. Agreed too.short for bmx frame.use. as noted in the description, perfect for trus designs and bridges...
    Squelch the weasel.
    Just reviving this thread to say, I think these are crank arms for BMX cranks.
    Also, Jay, if you still want them, email me (jim at nachlin dawt calm). The PMs seem to have disappeared.
    Quote Originally Posted by JaquesN View Post
    Yeah, I still do want them. I'm not sure what's going on with PMs. I'll email you.
  1. DH tubes or regular tubes
    By trap121 in forum Downhill - Freeride
    Last Post: 08-10-2013, 07:03 AM
  2. SR Suntour XCM - tubes shaking in the outer tubes
    By xr50rider14 in forum Shocks and Suspension
    Last Post: 06-23-2012, 05:12 PM
  3. Short seat tubes and long top tubes, WTH?
    By IMBAcile in forum 29er Bikes
    Last Post: 02-05-2012, 06:44 PM
  4. Tubes with No Tubes rims - problem
    By AndrewTO in forum Wheels and Tires
    Last Post: 02-11-2011, 09:45 PM
  5. Smaller Tubes Causing Mystery Pinch Flats?
    By amtbr in forum Wheels and Tires
    Last Post: 01-28-2011, 10:59 AM
