Results 1 to 51 of 51
Thread: My frame #1
    J_K
    J_K is offline
    My frame #1
    Here's my first frame project.
    I used Bikecad for the base design and then transferred main dimension to Rattlecad to get miter lengths and angles.
    The front triangle is Reynolds 631 .9/.6/.9 with externally butted 32.7/33.1mm 30.9mm ID seat tube, Dedacciai 29er stays and Paragon dropouts.
    Here's a couple of shots of the jig
    Setting head tube bottom height
    Mitered front triangle
    Bottle cage is there just for the test fit.
    My first ever brazing.
    Next job is to braze top tube cable guides.
    TT .9 butt lengths are pretty short and I would like to know if there's any problems with brazing cable guides to butt transition area?
    Not sure yet how I will do the chain stay miters, I have plans for the jig but it will not be ready for this frame. Most likely I have to file them but I'm little bit concerned about how they will turn out without the templates.
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    Nice jig and a very good start on your frame!!
    PAYASO 36er.....Live the Circus
    MR. 36er TROLL
    I'm sorry what part of "BIGLY" didn't you understand?
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Great start, very good mitres and fit.
    No problem with cable guides, they go where they have to go.
    Can you give detail on your brazing: torch size, flux, rod type. There is a need to refine here.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Quote Originally Posted by J_K View Post
    Interesting, and have never seen this style ... I'm curious why you decided on this joint configuration ... Can you explain why ?
    J_K
    J_K is offline
    Quote Originally Posted by Eric Malcolm View Post
    Eric
    Thanks for the info about the cable guides.
    I aware that I need to refine my brazing, biggest problem is my torch cheap propane torch. I used 56% silver there, it flowed nicely but focusing flame from the torch is tricky.
    I'll go to my friends place to braze cable guides with oxy-acetylene torch.
    Quote Originally Posted by bikeabuser View Post
    It's done that way because of 25mm offset seattube. By:Stickel does them that way and other builders also.
    Dec 2011
    Ok, happy with Silver. I wondered if heat was the problem, not enough of it. You can tidy up by coating the rim of the bottle ferrules with flux and reheat again. The silver should draw into the hole you drilled to fit the ferrule into the tube. Don't add anymore silver.
    Remember to use plenty of flux. 56% silver should go flat and not be lumpy or fillet.
    Try the O/A, you should be able to control better the flow with a hotter heat source. If you need to improve your own home tools, the MAPP gas will do the job. I have re-learned from O/A to do a good finish with it. You've done very well to get a good jig, as mentioned, fit and mitre, so a good frame is there.
    Enjoy and learn heaps.
    Eric
    Reputation: dhbomber's Avatar
    Nov 2006
    Subbed!!
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
    J_K
    J_K is offline
    I made little progress today.
    Downtube is tacked and top of the DT-HT joint is also welded as it was easier to weld it before toptube is tacked.
    I decided to weld the cable guides, because I didn't want to mess them with my poor brazing skills, not that my welding is any better. I'm happy with the result, I tried to keep most of the heat input on the cable guide to not cook the tube. I used ER312 1mm filler wire. Next time I'll try to get pressed cable guides from Pacenti.
    Reputation: Feldybikes's Avatar
    I might keep an eye on the welded cable guides if on the thin part of the tube. Silver no problem. TIG might freak me out. Might be worrying about nothing, though.
    Also, and you probably already know this but just want to be sure: weld all the way around for the compound joints on the BB/DT/ST/gusset (or whateveryoucallit). I.e. weld the DT to the BB completely, then the ST to the DT, then the gusset to all three. (This description assumes I interpretted the intersection of the joints from your drawing correctly, so modify if what I said doesn't make sense)
    Reputation: Beatniqwood09's Avatar
    Very cool. I like the BB-DT-ST joint. Building my first frame as well. Subscribed
    Nemophilist
    Reputation: TrailMaker's Avatar
    Well;
    You've obviously TIG welded before! Looks like you are ready to crank some serious rock & roll here. Looking forward to seeing your progress.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Moderator Moderator
    Reputation: Walt's Avatar
    Get the Pacenti guides for next time
    Those cast cable guides have always freaked me out because they're so rigid. TIG welding them is going to add to that stress-riserness, too. That said, IMO you are fine, go ride the darn thing.
    I prefer the Pacenti guides as they're less rigid (and they're stainless, which is nice once the paint wears off the guide). Looks like they are out of stock right now though.
    Very, very cool first project. Your welding looks great. Tacks a bit less so - try to start the tack on the non-mitered surface and not throw quite so much rod at it. Those are bordering on being problematic for causing failures from fatigue someday.
    -Walt
    J_K
    J_K is offline
    Quote Originally Posted by Feldybikes View Post
    Front cable guides are on the thick .9 part of the tube and rear cable guides are partly on the butt trasition area, but definitely not on the thin part of the tube. I'm not worried, but I will keep on them once the frame is in use. Rock Lobster seems to be welding all of his braze-ons.
    DT is welded to BB. Next I will tack the ST to the DT and the TT to the HT/ST. I will weld the gusset before chainstays.
    Quote Originally Posted by TrailMaker View Post
    Well;
    Actually I have not TIG-welded that much, but I find that lap joints(is that correct term for these kind joints?) are easiest joints to weld.
    Quote Originally Posted by Walt View Post
    -Walt
    Thanks for the info Walt.
    I will use Pacenti guides next time. I was going to order them for this frame, but shipping was too much. Then they were not available once I decided to order them despite high shipping costs.
    I'm not proud of those tacks, I should have done some practice welds before I started tacking since it's almost month when I last time welded something this thin.
    Today I welded the DT to the BB, I'm pleased with the results. I was able keep HAZ small and pretty consistent. The Paragon Machine Works BB welds nicely as it is not very thick, I also cut 1" vent hole to the BB.
    Rotating jig for better welding positioning, need to cut excess of the main beam to be able to rotate it all the way around. I'll add also back purge fittings to the BB, HT and ST cones later. There's also my cheap tig welder, the torch costs about the same as the machine
    BB-DT joint welded, BB cones suck heat nicely.
    Dec 2011
    Wow J K, you are a surprise package.
    Should have seen it coming, good jig, excellent mitres etc. Just not so good on braze, but a successful frame on the way first time. Will watch with interest.
    Eric
    Nemophilist
    OK...
    Well, TIG savant seems to fit then. Pretty decent work for no experience. Anything with parts at any angle to each other is considered filleting, I do believe, for what it's worth. Lapping is sort of short for OVER-lapping of some sort.
    J_K
    J_K is offline
    The front triangle is now fully tacked and pretty much fully welded.
    I had to improvise little bit to keep the seattube in place, in the future I will add tubeholder there.
    Gusset is also tacked in, will finish welding it once frame is out of the jig. The gusset was pretty hard file correctly, I had to redo it few times.
    I also cut off the cable guides as they were in really bad position.
    I'm trying to figure out how to miter chainstays, I have plans for the chainstay jig, but I'm not sure if I will get that done yet.
    Moderator Moderator
    Looking fantastic! Keep us updated!
    Those ST/BB braces are indeed a huge PITA. I never figured out a quick/easy way to do it. So I got a tube bender...
    -Walt
    J_K
    J_K is offline
    -Walt
    Thanks Walt.
    I made this 3d desing based on rattleCAD dxf file and added 1 1/4" tube there and then flattened that tube to get miter template. I'm still wondering how I was able to do that . It was pretty quick to do draw it, it took about ten minutes once I figured out how the program works. I'll definitely get tube bender at some point.
    Nemophilist
    Hey;
    You're already a better TIG welder than I am... jerk.
    Good move on the cable stays. Not sure what you were thinking there at first, but at least you kept thinking! I skipped them completely on my first frame. I knew I didn't know anything about them, and didn't want to botch them up like you did!
    Anything mitered at a severely acute angle like that brace is difficult. It takes a ton of patience and concentration - and sometimes 2-3 tries - to get a tight fit.
    J_K
    J_K is offline
    Hey;
    I keep trying, but there's still lots of room for improvements. I'm only showing my best weld beads anyway
    I'm not sure either what I was thinking with the cable guides First I had them clamped underside of the TT, but then I got that clever idea to place them side of the TT where your thighs will rub against them
    That's nice miter, did you file it or did you cut it with the hole saw?
    I'll keep filing the main tube miters, but I'd love to machine miter the chainstays
    Nemophilist
    Hey;
    I apologize for insinuating my work into your thread, but I wanted to lend you some support and encouragement, and relate that it is tough for everyone, every time. That tube was shaped first by a rough chop sawing, then running on the top roller of my belt sander, and finally by hand filing. It was a very long process, but it fits perfectly!
    The machine miters are really only a good starting point in my experience. In many cases, they can get you pretty close. It is often down to luck, skill, of course, and the accuracy of your equipment.
    The closer the tube joint is to 90* the more likely they will be to fit up right off the bat. If a tube also simply goes where it ends up, like my ST-to-TT brace, it still takes an enormous amount of time, but is not critical. When a tube has to fit exactly in a given position between two other tubes, like a TT or DT, the control of filing your way into a perfect fit is immeasurably valuable. You'd machine miter yourself close, but plan on filing your way to a tight fit. If you hit the mark right of the machine, great, but it is better to plan on being a tad long and filing in rather than wasting a piece of tubing. When fractions of a millimeter count, you better have a seriously accurate setup or you will be wasting a lot of material!
    Being able to toss a piece of tube in a machine and get a perfect fit the first time takes some pretty sophisticated equipment (for a hobbyist), and an enormous amount of prototyping of both jigging and final parts to land on a perfect fit with little to no hand work.
    I machine miter my CSs on a dedicated fixture. As good as it is, I have still had variable results. My first attempt got me a perfect fit straight away. The 2nd attempt for my Kroozer, while workable, took some fine tuning to perfect. I was a little disappointed by that, and I'm not sure where things went awry, but at least I had the skills to correct it. People that never learn to hand miter well would be lost.
    Moderator Moderator
    Is that the end of the butt?
    I am guessing the line on the downtube in the drawing is something else, but if that's the end of the butt, you should start over. You should have at least 25mm or so between any welded joint and the end of the butt.
    I was actually going to ask what you're using for a downtube, since many of them don't have butts long enough to work well with this sort of design. 100mm or so of BB end butt is nice to have.
    -Walt
    J_K
    J_K is offline
    No that line is not the end of the butt, it's just line on the drawing
    There's over 100mm of butt left at both ends of the DT.
    I did lot of research about butt placement before I started, so I'm aware about what kind of the butt placement you should be looking for. The TT is another story, there's only about 40mm of the butt left at the ST end and about 80mm at the HT. Next time I would like to use True Temper HOX2TT for the TT, that has nice long butts.
    The DT is Reynolds 631 BX5179 X 34.9 0.9/0.6/0.9 714 120.30.320.30.214
    -Walt
    J_K
    J_K is offline
    No problem at all Trailmaker, keep posting. Thanks for the great info.
    There will be now slight delay with the build as I'm still waiting my XX1 crankset to arrive.
    I want to check chainring clearance before I miter the chainstays.
    Dec 2011
    JK
    You are doing well and clearly have researched your topic well, I like and encourage that approach.
    You have concerns about the chainstay mitering.
    Frankly, they are not difficult to file. Looking at your main triangle to date, you have filed all joints and have excelled. I personally am proud of doing better than a machine cut with a file and yours is up there with anything shown in the forum. You also did that gusset for the BB. Now that is a difficult piece, particulary to clamp and finish as well as you have. Doing chainstays is a breeze by comparison.
    I think you will manage easily.
    Eric
    Nemophilist
    Yeh;
    I'm with Eric. I don't think you will find it that hard. CSs are tricky to be sure because of all that is going on, but the mitering is not really the hard part, and you already know how to do it, obviously.
    Charge!
    J_K
    J_K is offline
    Thanks for the encouragement!
    I'm not worried of filing the chainstays, the part that worries me is getting the miters in the same phase and length. I'm going to make simple jig from the existing parts to phase the dropouts and chainstay maybe tomorrow or next weekend.
    I find following flickr set from Fellet Brazing very helpful for hand mitering the chainstays Life of a Chain Stay Miter - a set on Flickr
    I'm going to weld dropouts to the chainstays before I start mitering the chainstays to the BB.
    That brings us to the next question. I'm considering my options how to cap the end of the chainstays or do I even need to cap them? I found this post from the Groovy Cycleworks blog, I like how Rody did them and in this post he brazed the dropout ends shut.
    I know that Walt likes to weld plate style dropouts, but I didn't find any close up pics of the dropouts from his blog. Walt, how do you cap the dropout ends when using plate style dropouts?
    I also need to find new crankset as I'm not going to get my XX1 crankset before march.
    That is not necessarily a bad thing, as now I can choose crankset with chainline that suits better for 1x10 drivetrain.
    Nemophilist
    Hey;
    First point; Working is the first priority. Square and even is also obviously a
    nice touch if you can see your way there.
    My setup may give you some ideas. It might not be the slickest, but it
    works well for me and did not cost thousands. You could replicate a lot of
    the function of what I have below on a table top or piece of MDF or
    whatever, with some clamps and tube blocks. My setup has many of the
    attributes locked and squared by default, but a homey made table topper
    setup could accomplish all of this just as well, if not as quickly.
    My CSs are working off of my dummy tire. If the clearances are right there,
    I then even the stays up to the jig and each other. I float the DO over the
    ends of the stays until I have everything set, and then do a clearance
    miter that allows me to bring the DOs down into position for tacking. Once
    they are tacked, I look to do my BB miter, which uses the front edge of
    the base platform as the BB center line.
    There are a few ways to finish miter the DOs. I sort of like the way I did
    my first ones. It takes some time but looks smooth and neat. I don't
    remember who suggested it now, but I think I posted asking about various
    methods. Once I got a clue, it sparked and idea, and it was smooth sailing!
    Rough tacking miter. This is where many people shape and fillet weld if
    brazing. It is really hard to resist, but save the finish welding here for the
    very last thing you do after all the other welding and squaring is done. If
    things walk on you and you need to make some correction to square up
    the rear wheel, you can just break the tack welds and tweak as
    necessary. I find it REALLY hard to be that patient!!!
    The CS is capped and finished. Then the rest of the seams are finished
    A F T E R the rest of the frame is welded and squared!
    Hope this helps!
    J_K
    J_K is offline
    Thanks again for the tips Trailmaker
    Nothing new to show.
    I got some v-blocks made for the chainstay jig while I have been waiting on the crankset to arrive. I wanted to have the crankset before mitering the chainstays to make sure there's enough room for the 156mm q-factor. I hope to make some progress next weekend.
    My low tech chainstay jig
    Nemophilist
    That's plenty of new;
    Low tech, high tech.. once it is done and built, the only one that knows is you, and the only real difference if it is a good setup is how long it takes. That looks plenty slick, and creative. Smart to wait for the cranks. There's nothing like having it all sitting there together to take measurements from.
    Looking great!
    Dec 2011
    JK
    You have a high competency level.
    How did you come by all the skills?
    Eric
    Harrumph
    Reputation: G-reg's Avatar
    JK, how are you going to slot the stays for the dropouts? In my self/internets taught experience it's a real pain in the ass to do cleanly.
    Slowly slipping to retrogrouchyness
    J_K
    J_K is offline
    JK
    Eric
    My skills come by trial and error, self learning and copying other peoples work .
    Honestly, I do read lot of blogs, forums and go through lot of Flickr albums and I'm trying to pick ideas from there.
    Machining is something I would like to do myself, but I don't plan to invest to that part any time soon.
    Luckily I found very reasonably priced machinist with quick turnaround time, so there's no plans to purchase any heavy machinery.
    Quote Originally Posted by G-reg View Post
    Slotting the chainstays is actually next thing to do before mitering the chainstays to the BB. I plan to do rough cut with a hacksaw and then file the dropouts to fit.
    Meriwether has a nice blogpost how to do it, Slotting chainstays for plate dropouts Meriwether Cycles
    Nemophilist
    I may have mentioned...
    This type of stay jig allows you to float the DO above the stay tip and a get a real good lines drawn for a first cut. Since you are brazing, you will slot into the end, I imagine. You can see from my pics that I trim off the outside of the tip, trim the stay flush, cap, and finish file.
    J_K
    J_K is offline
    That's one of reasons why I designed the axle holder to be adjustable, it also allows to use different shape stays. The axle holder is actually multi use piece, it can be used on the chainstay jig and in the future on the fork jig, currently it's also used on the frame jig.
    No I'm not brazing the dropouts, I'm going to weld them, but I'll do marking and cutting like you described there.
    Dec 2011
    Thanks JK
    I Mirror your Methods, it seems like I am watching myself at work in this thread.
    Keep up the good work.
    Eric
    J_K
    J_K is offline
    Small update
    The chainstays are now slotted for the dropouts. Tomorrow I'll shape ends of the chainstays and weld them. No capping needed for inside of the DO/CS joint.
    I need also figure out what to do with the cable guides, too bad Pacenti guides are still out of stock.
    Nemophilist
    Yessiree...
    3" cutoff wheel in hand, it's so nice to have all that stuff locked in place and be able to just nibble at the slots until they drop in, Tack, tack, and ready to miter!
    You can do your cut, miter, cap, and file, but don't forget to leave the final weld to the DOs until dead last!
    J_K
    J_K is offline
    It's done and ridable. No build pics of the stays because it did not go as planned. Chainstays are 6mm shorter than I planned to at 419mm, but there's still enough room between the tire and the seattube for 2.4" Ardent. The seatstays were easier to do than I thought. I'm not happy with the chainstays as they are way too outboard on the BB shell and I had to dimple the CS for the chainring clearance.
    I was able to braze the cable guides quite easily with my limited equipment once I got proper flux and silver rods.
    I really like how it rides, very nimble and easy to steer, it just goes where you want it to go. I'm glad that I read lot of posts about the front center etc. First plan had 20mm longer front center than I ended building. Now the front center is exactly "Walts magic number" 655mm, even without trying to get to the exact number.
    I'm already planning the next build, which will be a road bike.
    Thank you for everyone who have helped me! I Really Appreciate it!
    Crappy pic.
    Dec 2011
    Hey
    Well done JK, good looking bike you have there.
    Eric
    Nemophilist
    Hey;
    That's a fine looking machine. You should be quite proud. If it works well enough that you aren't tempted to saw it up within a couple of months, you did alright. And now the search for improvement begins!
    Harrumph
    Nicely done, nothing like the first ride on #1!
    Reputation: jay_ntwr's Avatar
    Congrats on #1!
    J_K
    J_K is offline
    Thanks for the comments, first ride was indeed quite satisfying and eye opener.
    I'm already thinking what should be done differently on the next frame. I want to make it steer little bit quicker, but I will not make new frame before I have tried this one with the suspension fork and that should quicken the steering little bit as rake is 48mm instead of 45mm on the carbon fork.
    No intentions of sawing it up at the moment.
    It's little bit heavier than I wanted, but I don't care, weight is 2145g.
    Harrumph
    That's more than light enough for a #1 mtb with a 44mm headtube. If you used tubing light enough to drop weight appreciably it'd be a Garage Queen.
    J_K
    J_K is offline
    Yes it's light considering the tubes I used and if I had wanted light frame I would have bought carbon frame, but that's not for me. Tubing I used, 44mm headtube, .9/.6/.9 1 1/4" toptube, .9/.6/.9 1 3/8" downtube, 1.1/.55/.9 30.9 ID seattube, and Deda stays.
    Nice Work J K, really inspiring!
    Nice looking ride! The fork looks weird to me, but different strokes....
    Where'd you get that seat tube?
    J_K
    J_K is offline
    Fork is really ugly, I don't like it at all, but it was cheapest tapered fork I could find. You should have seen it with the paint, black and green
    The seattube is 631 Reynolds, part number CX5287, I got the tubes directly from the Reynolds UK. It's little bit odd sized, 32.7mm at the bottom and the external butted part is 33.1mm. 33.1mm is actually really nice size since you can braze there piece of 0.9mm 1-3/8" so you can use 34.9mm seatpost clamp.
    Cool thanks. I read about those seat tubes awhile ago but I guess I didn't realize those were available yet. Wonder if there will be a US distributor anytime soon?
    J_K
    J_K is offline
    They also have 31.6mm ID seattubes available, or they should be available soon.
    Unfortunately I don't know about US distributors, but you should ask if Fairing has them available.
Members who have read this thread: 4
